Timer0 set up for 18F4520
nmeyer
PostPosted: Tue Nov 06, 2007 2:26 pm     Reply with quote
I am trying to use the rtcc timer in my program by setting up a rtcc_isr. HOwever, something is not running correctly. When i put in code for the correct number of interrupts per second, it runs way too slow. This is the first time i have used the 18F4520, so i am wondering if i am missing something in the set up of the chip. Can anyone quickly look through this code and see if there is a noticable error? I have used this timer isr in other programs (pic16F819) and it worked fine.
Compiler PCWHD V4.06
#include <18F4520.h>
#device adc=10
#include <stdio.h>
#include <math.h>
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES XT                       //High speed Osc (> 4mhz)
#FUSES BORV25                   //Brownout reset at 2.5V
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled
#use delay(clock=4000000,RESTART_WDT)
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,RESTART_WDT,ERRORS)
#define  INTS_PER_SECOND   1  //should be(4000000/(4X256X16))=244.14
//#include <Flex_LCD.C>
int   i,step,phase1,phase2;
char  reply,int_count,loop_int;
int   byte1,byte2,byte3,byte4,byte5,byte6,byte7,byte8,byte9,byte10,byte11,byte12;
int   byte13,byte14,byte15,byte16,byte17,byte18,byte19,byte20;
int   rbyte1,rbyte2,rbyte3,rbyte4,rbyte5,rbyte6,rbyte7,rbyte8,rbyte9,rbyte10;
int   rbyte11,rbyte12,rbyte13,rbyte14,rbyte15,rbyte16,rbyte17,rbyte18,rbyte19,rbyte20;
long  crc_result,seconds;
int16 crc,r_crc;
int32 tempbyte,disbyte,mult;
#int_rtcc
clock_isr()
   if(--int_count==0)                     //decrement counter until 0
      ++seconds;                          //count up seconds
      int_count=INTS_PER_SECOND;          //reset counter
      if (seconds>=65000)
         seconds=65000;
   setup_counters(RTCC_INTERNAL,RTCC_DIV_16);
   set_rtcc(0);
   enable_interrupts(INT_RTCC);
   enable_interrupts(global);
   set_tris_b(0b00000000);
   output_low(PIN_B5);
   int_count=INTS_PER_SECOND;             //used for timer
   seconds=0;
   while (true)
       if (seconds<=1)
         output_high(PIN_B5);
         output_low(PIN_B5);
       if (seconds>=3)
         seconds=0;
PostPosted: Tue Nov 06, 2007 2:39 pm     Reply with quote
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=30618
nmeyer
PostPosted: Tue Nov 06, 2007 2:53 pm     Reply with quote
Great. I knew I was missing something. Thanks
