alecms Guest
bootloading via USB |
Posted: Mon Oct 24, 2005 4:10 pm |
Has anyone been able to bootload code to a PIC 18f4550 through the chips internal USB transceiver? If so, I would be very greatful if you could please give me an overview of how this is done.
Thanks,
Alec |
asmallri
Posted: Mon Oct 24, 2005 6:39 pm |
Microchip have a bootloader for this chip on their site under USB solutions. Have you had a look at that one. _________________ Regards, Andrew
alecms Guest
Posted: Mon Oct 24, 2005 10:29 pm |
Thanks for the info. I looked at this but it seems as though this bootloader prevents one from using the USB port for anything besides updating firmware. I wonder if there are any more flexible solutions out there. |
asmallri
Posted: Mon Oct 24, 2005 11:10 pm |
Well if you need it to do something else then you are not really looking for a bootloader. Once the bootloader has loaded a program it passes control to the user program and it can do what it likes with the USB port. _________________ Regards, Andrew
alec
Posted: Tue Oct 25, 2005 3:20 am |
Have you been able to make this work? I suspect the difficulty would lie on the PC side. I don't see how you would switch from the dedicated bootloader USB driver provided by Microchip to another driver while the device is plugged in. |
asmallri
Posted: Tue Oct 25, 2005 6:10 am |
alec wrote: | Have you been able to make this work? I suspect the difficulty would lie on the PC side. I don't see how you would switch from the dedicated bootloader USB driver provided by Microchip to another driver while the device is plugged in. |
I have not tried Microchip's implementation but cannot see a problem. It enumerates initialise as device X for the bootloading process, then at the end of the bootloading process it disconnects from the bus (optional) then reconnects and enumerates as a totally different device. _________________ Regards, Andrew
alec
Posted: Tue Oct 25, 2005 11:54 am |
Thank for your help.
Alec |
