No luck with centering servo using interrupts
Harry Mueller
PostPosted: Sat Oct 22, 2005 11:50 am     Reply with quote
This newbie is trying to control (center) a servo using an interrupt on Timer_0 overflow. The code is compiling but nothing is happening at PIN_A0 and I'm a little over my head here so I'd appreciate some help. Here's the code:
#include <16F628.h>
#define quar_mov 250
#int_TIMER0           // This function is called every time
void servo_isr()      // the RTCC (timer0) overflows (255->0).
int position;            // For this program this shld be :) 50 times
int quarter = 2;      // per second.
position = quarter*quar_mov;
output_high(PIN_A0);
delay_ms(1);
delay_us(position);
output_low(PIN_A0);
set_timer0(0);
setup_timer_0( RTCC_INTERNAL | RTCC_DIV_64 );
Thanks.....Harry
dyeatman
PostPosted: Sat Oct 22, 2005 12:03 pm     Reply with quote
Harry,
If you look at the data sheet you will find the pin is also used for a comparator input. To get Pin A0 to work try disabling the comparators.
Harry Mueller
PostPosted: Sat Oct 22, 2005 1:13 pm     Reply with quote
dyeatman wrote:
Harry,
Tried that but it didn't seem to help.
Thanks....Harry
PostPosted: Sat Oct 22, 2005 1:40 pm     Reply with quote
Harry,
It works fine for me.
dyeatman
PostPosted: Sat Oct 22, 2005 1:44 pm     Reply with quote
Sorry,
That last post was mine.
I had to enable global interrupts to get the timer interrupt to work and it worked just fine for me. Make sure your oscillator is running.
set_timer0(100);
setup_timer_0( RTCC_INTERNAL | RTCC_DIV_256 );
Adding the lines below allows you to see if the oscillator is running.
output_toggle(PIN_B1);
Harry Mueller
PostPosted: Sat Oct 22, 2005 2:02 pm     Reply with quote
Great...it worked! Thanks!
I noticed some thing odd but it just turned out to be a timing issue.
Harry
