Maximilius Guest
Touch screen |
Posted: Sat Feb 15, 2003 5:11 pm |
Anybody have some examples about read a Touch screen panel (resistive) in C?
Best regards,
Maximilius
___________________________
Original Post ID: 11749 |
Hans Wedemeyer Guest
Re: Touch screen |
Posted: Sat Feb 15, 2003 11:18 pm |
Did you want to do it all in PIC or use a Touch Screen Chip like ADS7843 ?
Using the ADS7843 is easy. Then comes the question what do you want to do with the touch screen.
Several designs emulate a mouse, other use simple "Soft Zones" to control turn key appications.
I did a design for Soft Zones, sorry I can't publish the code as someone else paid me to write it for them, which means I don't own it !
However it was as simple as handling the interrupt from the AD7843 and converting the data to X,Y values. In the design I did, the data ended up in the PC via a CAN bus connection.
Original Post ID: 11755 |
s.nadir Guest
Re: Touch screen |
Posted: Thu Oct 20, 2005 4:54 pm |
i've a problem using ads7843, can i have a simple routine for reading x,y coordinates? my routine retrieve "random" values!
thanks nadir
s.nadir@libero.it |
