AD7998 driver
AD7998 driver
PostPosted: Wed Oct 19, 2005 2:13 pm     Reply with quote
Hi All,
Did someone wrote a driver for the I2c adc ad7998 ?
Where I can find it ??
Thanks,
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Wed Oct 19, 2005 4:19 pm     Reply with quote
Here's the code I used for reading the AD7998.
// I2C constants
#define I2C_TIMEOUT     100    // # of tries to start the i2c transaction
#define I2CWRITE        0x00
#define I2CREAD         0x01
// AD7998 constants (external ADC)
#define AD7998_VIN1   0x80
#define AD7998_VIN2   0x90
#define AD7998_VIN3   0xA0
#define AD7998_VIN4   0xB0
#define AD7998_VIN5   0xC0
#define AD7998_VIN6   0xD0
#define AD7998_VIN7   0xE0
#define AD7998_VIN8   0xF0
void i2c_init(int8 iAddr)
// PURPOSE:        Initiate the I2C transaction
// PRECONDITIONS:  I2C bus is free.
// POSTCONDITIONS: I2C transaction is initiated.  The target chip is addressed.
//                 The code, which has called i2c_init(), is responsible for ending the i2c transaction w/ i2c_stop().
//                 If i2c transaction didn't initialize, the error flag is set.
//                 The code, which has called i2c_init(), has to check the error flags at some point.
   int8 i;   // loop counter
   i = 0;
   do
      i2c_start();
      ++i;
      delay_ms(1);
   while (i < I2C_TIMEOUT && i2c_write(iAddr) == 1); // 0 returned for ACK
   if (i >= I2C_TIMEOUT)
      g_sSystemValues.Errors |= E_I2C;
}  // i2c_init()
int16 read_adc_AD7998(
      int8 iAddr,    // [in] I2C address of the ADC to be read
      int8 iChannel) // [in] address of the channel to be read.
//        AD7998 has 8 channels.  See also ADC constants.
// PURPOSE:         Read one channel on AD7998 ADC over the I2C bus
// POSTCONDITIONS:   The 12-bit value is returned as a 16bit integer.
//   I2C bus is freed.
// NOTE:          Unused channels are grounded on the board.
   int8 iRet[2];
   i2c_init(iAddr | I2CWRITE);   // initialize AD7998 for writing
   i2c_write(iChannel);            // command/address byte, start the conversion
   i2c_init(iAddr | I2CREAD);      // initialize AD7998 for reading
   iRet[1] = i2c_read();         // read the 1st data byte MSBs
   iRet[0] = i2c_read(0);        // read the 2nd data byte LSBs, NACK
   i2c_stop();                   // stop the I2C transaction
   return ( make16(iRet[1], iRet[0]) & 0x0FFF );   // mask out the 4 MSBs
}  // read_adc_AD79998()
PostPosted: Thu Oct 20, 2005 3:30 pm     Reply with quote
I wrote this code like te example but still it dosent work ...
can you tell me why ???
I'm using the ad7998 -0 AS is GND
union int16_2char
int16 int16_;
struct int8_
int8 H;
int8 L;
int16 read_adc7998(int8 reg){
union int16_2char ic;
ic.int16_ = 0;
i2c_start();
i2c_write(0x42|I2CREAD);
if(reg == AD7998_ALERT_STATUS || reg == AD7998_CYCLE_TIMER)
// 8bit read
ic.int8_.L = i2c_read();
// 16bit read
ic.int8_.H = i2c_read();
ic.int8_.L = i2c_read(0);
i2c_stop();
return ic.int16_;
[/code]
union int16_2char
int16 int16_;
struct int8_
int8 H;
int8 L;
ic.int16_ = 0;
i2c_start();
// 8bit read
// 16bit read
i2c_stop();
return ic.int16_;
[/code]
kender
PostPosted: Thu Oct 20, 2005 3:38 pm     Reply with quote
You don't specify a channel to read. You should do it imediately after you sdress the AD7998.
And by the way, how exactly it doesn't work?
What's your expected result?
What's your actual result?
PostPosted: Thu Oct 20, 2005 3:49 pm     Reply with quote
Also he's written it so in his 8-bit mode he's not doing a NACK on
the i2c read.
PostPosted: Fri Oct 21, 2005 3:23 am     Reply with quote
I corrected the 8 bit nak -> thanks.
There is a write function:
void write_adc7998(int8 reg,int16 data){
ic.int16_ = 0;
i2c_start();
i2c_write(0x42|I2CWRITE);
if(reg == AD7998_POINTER)
// pointer
ic.int16_ = data;
i2c_write(ic.int8_.L);
else if(reg == AD7998_ALERT_STATUS || reg == AD7998_CYCLE_TIMER)
// 8bit write
i2c_write(reg);
i2c_write((int8)(data));
// 16bit write
ic.int16_ = data;
i2c_write(ic.int8_.H);
i2c_stop();
the test looks like this:
write_adc7998(AD7998_HYSTERESIS_CH4, 0x55aa);
adc_val = read_adc7998(AD7998_HYSTERESIS_CH4);
I shold read adc_val as 0x55aa.
now whats wrong ...
