baraban Guest
2 rs232 interruptions |
Posted: Fri Oct 04, 2002 1:09 am |
Hello all,
Is it possible on a 16F8xx or 18xxxx chip to have two RS232 ports, with separate interruptions ?
I need to get data from a serial port by IT, and get data on another serial port (both on the same chip) to get data too.
But I need IT for both ! (one connected to a GPRS phone, so when someone call, I get data in the IT function, and another connected to a PC to get data at a high speed, so I need IT to avoid loosing chars).
Thanks in advance,
Regards,
Matt.
___________________________
Original Post ID: 7411 |
Phil G Guest
Re: 2 rs232 interruptions |
Posted: Fri Oct 04, 2002 5:56 am |
I just went through this:
Onthe PIC18 with 2 hardware serial ports (C6&C7, G1 & G2)
the INT_RDA is for the C6-C7 port, and INT_RDA2 is for the G1-G2 port.
Note here that kbhit() does not work for the G1-G2 port, so if you need this you need to work around by accessing the hardware diraectly:
#bit portg_kbhit = 0xFA4.5
and then instead of
if(kbhit())...
use
if(portg_kbhit)...
Phil
:=Hello all,
:=Is it possible on a 16F8xx or 18xxxx chip to have two RS232 ports, with separate interruptions ?
:=I need to get data from a serial port by IT, and get data on another serial port (both on the same chip) to get data too.
:=But I need IT for both ! (one connected to a GPRS phone, so when someone call, I get data in the IT function, and another connected to a PC to get data at a high speed, so I need IT to avoid loosing chars).
:=Thanks in advance,
:=Regards,
:=Matt.
Original Post ID: 7417 |
KenMac
But the manual says... |
Posted: Fri Aug 26, 2005 3:55 am |
says that value = kbhit (stream) is legal. Is this not true? |
Posted: Fri Aug 26, 2005 4:40 am |
Look at the date involved....
The problem though is that the approach is limited in speed, and I/O to the hardware UART using interrupts can then interfere with the timings of the software UART.
Using a MAX3100, a PIC with two hardware UARTs, or another really small PIC communicating via I2C/SPI, are the 'better' methods to get good reliability.
Andre Jr. Richard
Posted: Thu Oct 20, 2005 12:24 pm |
18F8722 |
ALFA 705
Posted: Thu Oct 20, 2005 2:17 pm |
be carefully with 18F8722 and others PICs family.
Microchip is working in a "bug" about their EUSART. This will resut in ERRATA.
That's all I can tell you.
ALFA 705 |
