Atma
Programming target PIC with another PIC |
Posted: Wed Oct 19, 2005 6:34 am |
Hi there
I have a project that i have to do using the PIC16F873 device. In this project i have to program a PIC16F873 device with another PIC16F873 device. I was wondering if CCS had built in functions that could help me do this and if yes which functions would they be. I have been trying to use the cc5x compiler but things didnt work out. I came to a dead end and things didnt quite work.
Another thing is that one person on this forum called Ttelmah gave me alot of great advice and thats how i knew what exactly to do. I only managed to get hold of this compiler yesterday and was wondering if he could help me out again if possible.
I really dont have much time left for my project. About 2 weeks and was hoping that he could give me some tips using this compiler and how to do my project in C.
All help will be greatly appreciated.
asmallri
Posted: Wed Oct 19, 2005 7:52 am |
On several projects I have used a master PIC to program slave PICs (PICs that are downstream from the master that cannot be reached directly). I have bootloaders in the master and slave PICs. I set up the Master PIC bootloader to have a special "Transparent Mode". In this mode it tranparently echo anything on its user interface port to whatever port or ports connect to the slave PICs. When I have finished programming the slave PICs I take the master out of transparent mode.
One way of doing this is to define your own unique "type 4" intel hex record which a master will use to put itself in transparent mode and some termination control character to drop it out of this mode. When in transparent mode the master examines the next character received via the user interface, if it is not the termination character it passes it to the slave interface. _________________ Regards, Andrew
Atma
Posted: Wed Oct 19, 2005 8:04 am |
asmallri wrote: | On several projects I have used a master PIC to program slave PICs (PICs that are downstream from the master that cannot be reached directly). I have bootloaders in the master and slave PICs. I set up the Master PIC bootloader to have a special "Transparent Mode". In this mode it tranparently echo anything on its user interface port to whatever port or ports connect to the slave PICs. When I have finished programming the slave PICs I take the master out of transparent mode.
One way of doing this is to define your own unique "type 4" intel hex record which a master will use to put itself in transparent mode and some termination control character to drop it out of this mode. When in transparent mode the master examines the next character received via the user interface, if it is not the termination character it passes it to the slave interface. |
Hi there
Thanks for your reply..
What I have to do in this case is program a target PIC using another PIC in the sense that this PIC should be able to erase, write to, read from and verify the target PIC. I have been following the PIC specification guide so far and have been trying to follow the commands..Did it so far using cc5x compiler. only thing is that its not working so thought to try out the ccs compiler since this is where i got my idea from.
So what i want to know is how would i erase a target PIC or write to a target PIC for instance using this compiler?Would it be difficult to convert from cc5x to the ccs compiler?
thanks |
asmallri
Posted: Wed Oct 19, 2005 10:05 am |
There are a couple of ways you can do this. One is to emulate an external programmer and program the PIC using ISCP. The second way is for the target PIC to contain a bootloader. In which case you send commands to the target PIC. For example, the erase program memory command would erase all program memory space except the space occupied by the boot loader. This is the method I use. You could look at the sample CCS bootloader code to see how they do it. Similarly you could issue a command to read the program memory, in this case the bootloader would send all the program memory space except the space occupied by the bootloader. _________________ Regards, Andrew
Atma
Posted: Wed Oct 19, 2005 10:12 am |
asmallri wrote: | There are a couple of ways you can do this. One is to emulate an external programmer and program the PIC using ISCP. The second way is for the target PIC to contain a bootloader. In which case you send commands to the target PIC. For example, the erase program memory command would erase all program memory space except the space occupied by the boot loader. This is the method I use. You could look at the sample CCS bootloader code to see how they do it. Similarly you could issue a command to read the program memory, in this case the bootloader would send all the program memory space except the space occupied by the bootloader. |
hi there
What do you mean by emulate an external programmer?
thanks |
asmallri
Posted: Wed Oct 19, 2005 10:39 am |
Lots of PIC programmers program the PIC in cicuit using In Circuit Serial Programming (ICSP). The Warp13A is an example of a PIC programmer that uses a PIC to program other PICs. _________________ Regards, Andrew
Atma
Posted: Wed Oct 19, 2005 10:45 am |
asmallri wrote: | Lots of PIC programmers program the PIC in cicuit using In Circuit Serial Programming (ICSP). The Warp13A is an example of a PIC programmer that uses a PIC to program other PICs. |
Hi..
ok i think thats the way that i have been working so far..because i have been using the in-circuit programming specification guide in order to program my target device. only problem is that the way that i did it doesnt work. I am not sure if it is a hardware problem or a software problem.
Would you have any advice using this method for me? |
asmallri
Posted: Wed Oct 19, 2005 10:49 am |
Sorry - I do not use that method myself - bootloaders are easier :-) _________________ Regards, Andrew
