About I2C problem.
bhaven
About I2C problem.
PostPosted: Wed Oct 19, 2005 11:26 am     Reply with quote
I have a problem with using the I2C memory. When the command for a write is given to the microcontroller, it hangs. What should i do ??
Even there's a problem with read command.
Please Reply.
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Wed Oct 19, 2005 11:56 am     Reply with quote
There's something wrong with the slave then. If you issue a 'write' to a device that physically isn't there, then it wont hang. instead you'll get 0xFF when you do a read. If you write to a device that is not working right, then your master PIC can hang.
The Code Examples forum has plenty of examples of both Master and Slave pics.
