asunca
getch() |
Posted: Fri Oct 14, 2005 8:12 am |
in the main program where the getch() function is called, the program gets into trouble. i ve just used the example code ex_stwt.c and the simplest example ex_sqw but i couldnt make them work. and i couldnt use getch() with hyperterminal. ive tried using kbhit() option but it also didnt work. pic sends data but just a simple echo thing cannot be done.
while (true)
putc( getc() +1);
what should be done? |
Mark
Posted: Fri Oct 14, 2005 11:55 am |
First, why are you adding 1.
Second, post a complete small test program. |
SherpaDoug
Posted: Fri Oct 14, 2005 5:44 pm |
You say it doesn't work, but you don't tell us what it doesn't do. The code you show should run but we don't know what you are expecting. _________________ The search for better is endless. Instead simply find very good and get the job done. |
asunca
Posted: Sat Oct 15, 2005 1:22 am |
#include <16F877.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, errors,BRGH1OK)
printf("start");
putc( getch()+1 );
when you write 'A' computer prints 'B'. this the 'not working small program' .
start is seen but no action on the receive pin. serial port works properly verified by the loopback. |
Humberto
Posted: Mon Oct 17, 2005 7:45 am |
#include <16F877.h>
#fuses XT, NOWDT,PUT, NOPROTECT, BROWNOUT, NOLVP
main()
char c;
printf("start");
c = getc();
putc(c + 1);
Humberto |
