where is the mistake?
Goto page 1, 2  Next
muahaha95
PostPosted: Thu Oct 13, 2005 2:19 pm     Reply with quote
hi all
my code is
#INCLUDE <18F452.H>
#CASE
#USE DELAY(CLOCK=16000000) //********************************* ! ! ! ! ! !
#FUSES HS,NOWDT,NOPROTECT,NOLVP
#DEFINE VER_MAJOR 0
#DEFINE VER_MINOR 01
#USE RS232(BAUD=19200,XMIT=PIN_E0,INVERT,STREAM=DEBUG)
#ZERO_RAM
#define use_PICDEM2_lcd TRUE
#if defined use_PICDEM2_lcd
   #define  lcd_en  PIN_A1
   #define  lcd_rw  PIN_A2
   #define  lcd_rs  PIN_A3
   #define  lcd_type 2           // 0=5x7, 1=5x10, 2=2 lines
   #define  lcd_line_two 0x40    // LCD RAM address for the second line
   #define  d_cycle 1
#endif
void lcd_send_nibble( BYTE n ) {
   n=n&0x0f; //Strip off the top 4 bits.. This only sends bit 3:0
   output_d(n);
   delay_cycles(d_cycle);
   output_high(lcd_en);
   delay_us(20);
   output_low(lcd_en);
BYTE lcd_read_byte() {
   BYTE low,high;
   output_high(lcd_rw);
   high = input_d(); //using d0:d3 for 4 bit data bus
   output_low(lcd_en);
   delay_us(1);
   low = input_d(); //using d0:d3 for 4 bit data bus
   output_low(lcd_en);
   return((high<<4) | low);
void lcd_send_byte( BYTE A0, BYTE n ) {    //A0:  0=instruction, 1=Data
   output_low(lcd_rs);
   while ( bit_test(lcd_read_byte(),7) ) ; // wait until busy flag is low
   if (A0==0){ output_low(lcd_rs);} //0=Instruction  and 1=Data
   if (A0==1){output_high(lcd_rs);} //0=Instruction  and 1=Data
   output_low(lcd_rw);
   output_low(lcd_en);
   lcd_send_nibble(n >> 4);
   lcd_send_nibble(n & 0xf);
void lcd_init() {
   BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
   // These bytes need to be sent to the LCD for initialization.
   BYTE i;
   //fprintf(debug,"Init!!\n\r");
   output_low(lcd_rs);
   output_low(lcd_rw);
   output_low(lcd_en);
   delay_ms(15);
   for(i=1;i<=3;++i) {
      lcd_send_nibble(3);
      delay_ms(5);
   lcd_send_nibble(2);
   for(i=0;i<=3;++i){
      lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
   BYTE Data;
   if(y!=1)
      Data=lcd_line_two;
      Data=0;
   Data+=x-1;
   lcd_send_byte(0,0x80|Data);
void lcd_putc( char c) {
   switch (c) {
      case '\f'   :
         lcd_send_byte(0,1);
         delay_ms(2);
      case '\n'   :
         lcd_gotoxy(1,2);
      case '\b'   :
         lcd_send_byte(0,0x10);
      default     :
         lcd_send_byte(1,c);
char lcd_getc( BYTE x, BYTE y) {
   char value;
   lcd_gotoxy(x,y);
   while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
   value = lcd_read_byte();
   output_low(lcd_rs);
   return(value);
{ lcd_putc("savas");
  lcd_putc();
but compuer said
Error[51]   C:\savas\a.c 123 : A numeric expression must appear here
Halting build on first failed translation as user preferences indicate.
please help me
PostPosted: Thu Oct 13, 2005 2:27 pm     Reply with quote
Which line in your program is line 123 ?
muahaha95
lcd_putc();
PostPosted: Thu Oct 13, 2005 2:29 pm     Reply with quote
lcd_putc();
PostPosted: Thu Oct 13, 2005 2:35 pm     Reply with quote
lcd_putc() requires a parameter.
Change your program to look like this:
lcd_putc("savas");
MUAHAHA95
THANK YOU PIC PROGRAMMER
PostPosted: Thu Oct 13, 2005 2:39 pm     Reply with quote
THANKS
muahaha95
to PIC PROGRAMMER
PostPosted: Thu Oct 13, 2005 2:47 pm     Reply with quote
hEY MY Friend I ask a last question
I build the program but compuer said that
No Errors
BUILD FAILED: Thu Oct 13 23:44:52 2005
what is problem ?
PostPosted: Thu Oct 13, 2005 2:52 pm     Reply with quote
Look at Mark's reply at the end of this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=21983&highlight=halting+build+first+failed+translation
muahaha95
only led work
PostPosted: Thu Oct 13, 2005 3:01 pm     Reply with quote
HEY MY FRIEND PROGRAM WORK BUT LCD DONT WORK ONLY LED WORK
WHAT DO YOU THINK ABOUT IT?
PostPosted: Thu Oct 13, 2005 3:06 pm     Reply with quote
What board are you using to test the LCD ? Are you using a
Microchip PicDem2-Plus board, or something else ?
muahaha95
About Board
PostPosted: Thu Oct 13, 2005 3:08 pm     Reply with quote
I used PICDEM2 PLUS
PostPosted: Thu Oct 13, 2005 3:32 pm     Reply with quote
That driver doesn't work. (sorry treitmey).
Use this one. It works. I tested it just now with a 18F452 on a PicDem2-
Plus board. It requires no changes. Just drop it in.
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
MUAHAHA95
thanks
PostPosted: Thu Oct 13, 2005 3:36 pm     Reply with quote
thanks for all things PIC PROG....
treitmey
PostPosted: Thu Oct 13, 2005 3:42 pm     Reply with quote
What doesn't work? Perhaps I should update the driver.
This little test worked.
#INCLUDE <18F452.H>
#CASE
#DEFINE VER_MAJOR 0
#ZERO_RAM
#include "picdem2.c"
int8 data;
//======================= MAIN ============================//
  setup_adc_ports(NO_ANALOGS);
  set_tris_a(0);set_tris_b(0);set_tris_c(0);set_tris_d(0);
  fprintf(DEBUG,"STARTING CRI Test.\n\r");
  fprintf(DEBUG,"FIRMWARE VERSION %u.%02u\n\r",VER_MAJOR,VER_MINOR);
  printf(lcd_putc,"TEST");
  while(TRUE){
////                 PICDEM2_LCD.C                                 ////
////                 Driver for common PICDEM2 PLUS LCD modules        ////
////  lcd_init()   Must be called before any other function.           ////
////  lcd_putc(c)  Will display c on the next position of the LCD.     ////
////                     The following have special meaning:           ////
////                      \f  Clear display                            ////
////                      \n  Go to start of second line               ////
////                      \b  Move back one position                   ////
////  lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1)    ////
////  lcd_getc(x,y)   Returns character at position x,y on LCD         ////
   #define  d_cycle 1
#endif
   output_d(n);
   delay_us(20);
   output_low(lcd_en);
   BYTE low,high;
   output_low(lcd_en);
   delay_us(1);
   output_low(lcd_en);
   output_low(lcd_rs);
   output_low(lcd_rw);
   output_low(lcd_en);
void lcd_init() {
   BYTE i;
   output_low(lcd_rs);
   output_low(lcd_rw);
   output_low(lcd_en);
   delay_ms(15);
   for(i=1;i<=3;++i) {
      lcd_send_nibble(3);
      delay_ms(5);
   lcd_send_nibble(2);
   for(i=0;i<=3;++i){
   BYTE Data;
   if(y!=1)
      Data=lcd_line_two;
      Data=0;
   Data+=x-1;
   switch (c) {
      case '\f'   :
         lcd_send_byte(0,1);
         delay_ms(2);
      case '\n'   :
         lcd_gotoxy(1,2);
      case '\b'   :
      default     :
         lcd_send_byte(1,c);
   char value;
   lcd_gotoxy(x,y);
   output_low(lcd_rs);
   return(value);
to PCM programmer
about last code
PostPosted: Thu Oct 13, 2005 3:45 pm     Reply with quote
Hey my friend
second program which you send only run led lamps but lcd is not work
I think main program is not enough
lcd_putc("savas");
what do you think about it?
to TREITNEY
about main
PostPosted: Thu Oct 13, 2005 3:52 pm     Reply with quote
hey TREITNEY
thanks for main code
but still LCD doesnt work only led lamps work
I dont know where is the my mistake
Goto page 1, 2  Next
Page 1 of 2
