Need help to understand include file
PostPosted: Sat Oct 15, 2005 9:37 am     Reply with quote
I want to read data from a 24LC128. I'm using the include file 24128.
My code hangs in my for loop:
Also, after reading data sheet and lots of other people's code here, I don't understand where in the include file the contents of the address are advanced.
-I thought a pointer would be needed here?
-I also don't understand why shifting 5 (not 4, not 8) bits?
-Also can someone tell me what significance is this number - #define EEPROM_SIZE 16384
-What controls the timing of the eeprom?
The following is an excerpt from the include file 24128- where do the contents of the address advance?
byte read_ext_eeprom(long int address) {
   byte data;
   i2c_start();
   i2c_write(((0xa0)|(hi(address)>>5))&0xfe);
   i2c_write(hi(address)&0x3f);
   i2c_write(address);
   i2c_start();
   i2c_write((0xa1)|(hi(address)>>5));
   data=i2c_read(0);
   i2c_stop();
   return(data);
And here's my code where it hangs in the for loop, just after the LED blinks. I only need to read a long file from the memory, only writing to send control bits. ps. I can't access a scope until Monday.
#include <16F877.H>
#fuses HS,NOWDT,NOPROTECT, PUT, BROWNOUT, NOLVP    // changed to HS for 20 mHz
#use delay(clock=20000000)                           // adjust for resonator frequency
#use i2c(Master, SDA=PIN_C4, SCL=PIN_C3)           // set up options (pic is master + pinouts)
#include <LCD_16f877A.c>
#use standard_io(c)
#use fast_io(a)
#include <24128.c>
//test eeprom
      int hex, i;
      int test;
      long int address;
      main()
      setup_adc_ports(NO_ANALOGS);
      setup_adc(ADC_OFF);
      disable_interrupts(global);
      init_ext_eeprom();
      i2c_start();                                  // built in function to start
      output_high (PIN_A0);                         // test
      output_low (PIN_A0);                          // test
      i2c_write(0xA1);                              // send control byte to eeprom 'read'
      i2c_start();                                  // restart to read
       for (i=0; i<50; i++)                         // this loop = # bytes in hex file "hex"
       hex = read_ext_eeprom(0x00);           //what I think I am doing here is reading the contents of the eeprom starting at address 0000
       output_high (PIN_A0);                        // init test
       printf(lcd_putc,"\feeprom", hex);         // test LCD
       output_low (PIN_A0);                         // LED off
Any help/advice thank you!
SophE
PostPosted: Sat Oct 15, 2005 10:05 am     Reply with quote
If you want the address to 'advance', _you_ advance it. The driver just accesses the specified address.
You don't need to access the I2C controls themselves. Just use the read routine on it's own. It already sends the address, and starts/stops the transaction.
So:
       hex = read_ext_eeprom(i);           //read from address 'i'
Get rid of your own I2C code in the initialisation, and it should work.
