sadlpx
| Chinese scales low voltage falling edge |
Posted: Tue Oct 11, 2005 12:24 pm |
Followup to the original post for reading Chinese digital scales output. Lower portion of this post has link to site. Trying to read clock input shifting from ~0 to ~1,6v. Not having any luck pulling into CCP_isr on falling edge. Any suggestions on what can i do to bump up the clock signal to give good solid h_to_l transition.
I'm trying to read the output from some chinese calipers. The output stream is 2x 24bit words back to back (total time about <1 ms), repeating at 50hz or every 20ms. Signal clock starts out with a 15-19 ms low then high for 55us, 24 bit word, high 110us, 24 bit word, high 55us then low for 15-19ms, repeat. Reading seems simple just a shift in routine reading on the falling edge. My problem is I'm having trouble filtering to the first falling edge. how could i set up to use the long (19ms) low to start my read cycle.
More data and scope images on the scales electronics are at this link.
http://www.shumatech.com/support/chinese_scales.htm |
