Bit toggling a variable
MikeW
PostPosted: Wed Oct 12, 2005 6:29 am     Reply with quote
I have spent an hour trying to sort this out, and failed.
I am trying to toggle a bit in a variable.
I define a flag
int16 General_Flags1;
then define the bit
#define T_1Sec_Toggle_Flag T_Timer_Flags,15
so, i think that bit 15 of General_Flags1 holds my boolean
I now wish to toggle that bit by using something like :-
#define bit_toggle(my_bit) {#asm btg my_bit #endasm}
of course, this only works for a byte, so i get an error saying it can only be 0..7, not 15
can some guru help ?
is there a better way.
Basically, I am looking for a function like output_toggle(pin), which works with a variable of more than 8bits, rather than a pin.
Mike
Mark
PostPosted: Wed Oct 12, 2005 6:40 am     Reply with quote
The PIC is an 8 bit machine and thus only 0-7 is allowed. What you must do is use bit 7 of the upper byte. For CCS this is &myvar + 1 when using assembly. Another option would be to use a struct to define the bits and then just do a myvar.bit15 = !myvar.bit15;
Neutone
PostPosted: Wed Oct 12, 2005 8:06 am     Reply with quote
This is not a function but it is easy to read.
#bit  T_1Sec_Toggle_Flag = T_Timer_Flags.15
T_1Sec_Toggle_Flag=!T_1Sec_Toggle_Flag;
MikeW
PostPosted: Wed Oct 12, 2005 8:17 am     Reply with quote
looks good to me, many thanks
MikeW
