A/D Pin A5 always high?
Foppie
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Thu Oct 06, 2005 7:05 am     Reply with quote
when I run a Analog/Digital test on my PIC16F877A with the pins A0, A1, A2, A5 and pin A3 as Vref all works but pin A5. Pin A5 always gives 1023, no matter what voltage I put on it's line.
i use following the following code to initialize the AD ports:
setup_adc_ports(A_ANALOG_RA3_REF); //sets A0, A1, A2 and A5 to analog and A3 to Vref
setup_adc(ADC_CLOCK_DIV_32); // define clock settings
Since the other pins work I guess and the hardware on all ports is the same I think I forgot to initialize something in my software. But I cannot find anything on the Datasheet Confused
Can someone help me?
PostPosted: Thu Oct 06, 2005 7:14 am     Reply with quote
Have you looked carefully at the pin diagrams. 'AN5', is not on pin 'A5', but on E0. AN4, is actually on pin A5. So you need to setlect the analog channel '4', to actually read a voltage on 'A5' (confusing...).
Foppie
PostPosted: Thu Oct 06, 2005 7:29 am     Reply with quote
This did it! Thanks.
Now do I have another question: how do I define RA4, since RA5 is AN4?
Mark
PostPosted: Thu Oct 06, 2005 9:01 am     Reply with quote
Define RA4 as what??????
Do you mean where is AN5? If so, its on E0.
Foppie
PostPosted: Fri Oct 07, 2005 12:44 am     Reply with quote
I first defined pin RA5/AN4 as PIN_A5, but as Ttelmah said I should define it as PIN_A4. Now My question is, how should I define pin RA4/TOCKl (I first thaught I should define it as PIN_A4 but since that is another pin I don't know how to define it)?
P.S.
I do not use Timer0
Mark
PostPosted: Fri Oct 07, 2005 7:16 am     Reply with quote
NO! RA5 is PIN_A5! But RA5 is AN4. RA4 is PIN_A4, confused yet Razz
Foppie
PostPosted: Fri Oct 07, 2005 7:41 am     Reply with quote
huh?
I first defined RA5/AN4 as PIN_A5 but that didn't work. Now I defined RA5/AN4 as PIN_A4 and it is working...
But now you say my non-working code should be working an dmy working code should not??? Shocked
I am getting very, very confused here Confused
(probably end-of-the-week meltdown....)
I will test it monday all over again and post my results...
thanks for your help!
Mark
PostPosted: Fri Oct 07, 2005 7:58 am     Reply with quote
RJ never said anything about defining something as PIN_A4. He said that RA5 (PIN_A4) is analog channel 4. When you set the adc channels, you do not use PIN_Ax. You use a number instead.
Foppie
PostPosted: Mon Oct 10, 2005 12:33 am     Reply with quote
I finally understand now! Thank you very much
