stack overflow in MPLAB run mode
TIMT
PostPosted: Mon Oct 03, 2005 5:26 am     Reply with quote
I'm using MPLAB V7.00 and the latest version of CCS. When I compile and then RUN my project in MPLAB I keep getting UART-W0006 warnings and stack overflow problems. I can't seem to put my finger on what is wrong. I've attached the code, it's fairly simple. If I don't setup the UART the problem goes away, it also occurs when using printf to an LCD. Any ideas?
#include <16F877A.h>
#fuses NOWDT,XT, PUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, NOWRT
#use rs232(baud=2400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
int M25P40_id();      // Prototype for reading the ID of M25P40.
#define HOLD_bar PIN_C0      // Used for the M25P40 flash routines
#define WR_bar   PIN_C1      // Used for the M25P40 flash routines
#define SYNC_bar PIN_B6      // Used for the M25P40 flash routines
int dataout;
    while (1)
    dataout = M25P40_id();                 // Read the M25P40 ID into data
int M25P40_id()      // Function for reading the ID of a M25P40 flash device.
    int data;
    setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_16 | SPI_XMIT_L_TO_H);
    output_high(SYNC_bar);                // Sync_bar line high
    output_low(SYNC_bar);                // Sync_bar line low
    spi_write(0b10101011);         // Read ID.
    spi_write(0x00);            // Dummy byte
    data = spi_read(0x00);                      // Read data
    setup_spi(SPI_SS_DISABLED);         // Disable the SPI bus
    return data;
WARNING MESSAGES GENERATED :-
UART-W0006: Receive file has no data or failed to attach
when UART receive mode Enabled.
CORE-E0001: Stack over flow error occurred from instruction at 0x000168
Tim
PostPosted: Mon Oct 03, 2005 7:06 am     Reply with quote
Have you possibly got a stimulus file setup in the simulator?. I have seen similar behaviour, when I had the simulator set to receive characters, and had not included any code to handle them.
TIMT
PostPosted: Mon Oct 03, 2005 8:02 am     Reply with quote
Hello there, No I haven't a stimulus file set up, that may be the problem. I think I may need to have a look at creating one. Thanks
Tim.
Tim
PostPosted: Mon Oct 03, 2005 10:53 am     Reply with quote
Vs. 7.00 has problems with the UART1 simulator. Here is a thread
on the Microchip forum about it.
http://forum.microchip.com/tm.asp?m=64251&mpage=1&key=uart%2Dw0006&anchor#64251
You shouldn't be using 7.00. I know from my experience that it
has problems with UART1. Download vs. 7.21 or later. I know that
it works OK with UART1.
TIMT
PostPosted: Tue Oct 04, 2005 2:29 am     Reply with quote
Thanks for your reply, I'll update MPLAB when I get chance.
Tim
TIMT
PostPosted: Tue Oct 04, 2005 3:20 am     Reply with quote
Thanks for your help. I updated to V7.20 and all my warning messages to do with stack overflow and the UART seem to have vanished! touch wood.
Regards Tim.
Tim
TIMT
PostPosted: Thu Oct 06, 2005 6:44 am     Reply with quote
Hi there, Confused
Having updated to MPLAB V7.20 then V7.21 which got rid of the UART problem, I've found that when I try to assemble previous assembly code projects I get a CONFIG directive error, so unfortunately I've had to go back to V7.00 until Microchip get back to me with an answer. I'm in the process of converting my old .asm projects to .c ones with ccs but until then I'll have to stick with v7.00 unless anyone here knows the answer?
Tim
TIMT
PostPosted: Thu Oct 06, 2005 8:57 am     Reply with quote
Just for info, the problem was with the NEW directive in V7.20 called CONFIG - was __CONFIG. I had a label called CONFIG in my .asm code which it now thinks is a directive and through up an error. I renamed the label CONFIG to MYCONFIG and ok now. I don'f know if CCS would ever generate a label called CONFIG I hope not. Must be a lot of code out there with CONFIG as a label.
Tim
