Interrupt routine can't call function??
SBS
PostPosted: Thu Oct 27, 2005 8:50 pm     Reply with quote
I've got a timer setup to interrupt. Then on every third interrupt I want to call my read_adc() function. My code executes, but it doesn't ever appear to actually go into the read_adc() function. Nothing comes over RS232 from the read_adc() function. Also, it (MPLAB) won't let me put a breakpoint in the read_adc() function.
Why isn't the read_adc() function executing?
#INT_TIMER2
void clock_isr()
if (count = 2){
   printf(" read ADC ");
   read_adc();
   output_toggle(PIN_B2);
   count = 0;
   count ++;
void read_adc()
BYTE data1;
BYTE data2;
BYTE data3;
printf(" _ ");
spi_write(0x02);   // Comm reg
spi_write(0x87);   // ADCCON REG, Read Channel 1
spi_write(0x44);   // Comm reg, Get ready to read
data1 = spi_read(0x00);      // Read data 8-bits (data 0:7)
printf(" %X ", data1);
data2 = spi_read(0x00);      // Read data 8-bits (data 8:15)
printf(" %X ", data2);
data3 = spi_read(0x00);      // Read data 8-bits (data 16:23)
printf(" %X ", data3);
enable_interrupts(INT_RB);
printf("Starting program... ");
// Cycle ADC ~RESET Pin
output_low(ADC_RESET);
output_high(ADC_RESET);
// Setup SPI to ADC
setup_spi(SPI_MASTER | SPI_H_TO_L| SPI_CLK_DIV_64);
change_spi_mode(0);
setup_timer_2(T2_DIV_BY_16, 255, 16);
// Initialize ADC
init_adc();
while (TRUE){}
Thanks,
Sal
PostPosted: Thu Oct 27, 2005 9:31 pm     Reply with quote
There are several criticisms that could be made, but at a minimum,
the lines shown in bold below should be corrected.
#INT_TIMER2
void clock_isr()
if (count = 2){
read_adc();
count = 0;
count ++;
Hint: Look at a list of C operators.
void read_adc() {
BYTE data1;
BYTE data2;
BYTE data3;
Hint: Look in the CCS manual at the list of functions.
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Thu Oct 27, 2005 9:33 pm     Reply with quote
I don't know if this is the cause of your problem (it doesn't look like it), but the statement in your timer ISR
count = 2
is assignment, and it always returns true . Did you actually want
count == 2
SBS
PostPosted: Thu Oct 27, 2005 9:39 pm     Reply with quote
Thanks for the comments. I realized the count = 2 problem. It was a typo. Smile
Ah... I guess I shouldn't name my functions the same as CCS functions, huh?
Thanks!
