akokyaw
Please check my eeprom read program |
Posted: Wed Oct 05, 2005 9:50 am |
I have some proble with reading eeprom (24C04). Please check my codes as follow and make suggestion.
#include <16F877.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) // Jumpers: 8 to 11, 7 to 12
#include <2404.c>
#define size 255
int buf,i;
long int add;
init_ext_eeprom();
add=0;
i=0;
delay_ms(250); delay_ms(250); delay_ms(250); delay_ms(250);
while(1) {
for(add=0; add<size; add++) {
buf=read_ext_eeprom(add);
printf("\r\nReading from EEPROM... Address= %ld Value= %x",add,buf);
output_b(buf);
Delay_ms(100);
The above code is not working. Any idea? But the below code is working and I really do not know why? Please check it out. The only difference is using "Delay_S(1);" function and four "delay_ms(250);" built-in function. Compiler is 3.227.
#include <16F877.h>
#include <2404.c>
#define size 255
void Delay_S(int delay) {
int i1;
for(i1=0; i1<delay; i1++){ delay_ms(250); delay_ms(250); delay_ms(250); delay_ms(250);}
int buf,i;
long int add;
init_ext_eeprom();
add=0x00;
i=0x00;
Delay_S(1);
while(1) {
add=0x00;
while(add<size) {
buf=read_ext_eeprom(add); // the memory and show it on leds,it shoaled be the same like the address
output_b(buf);
Delay_ms(100);
add++;
Thanks,
Ako |
Posted: Wed Oct 05, 2005 2:15 pm |
There's no reason for a delay to be required, normally.
My guess is that you have a very slow rise time on your power supply.
I assume your Vdd voltage is +5 volts.
Try adding the two fuse settings shown in bold, below:
#fuses XT,NOWDT,NOPROTECT, BROWNOUT, PUT, NOLVP
Those settings will make the startup be more reliable if the
problem is due to a slowly rising Vdd. |
akokyaw
Posted: Wed Oct 05, 2005 6:36 pm |
Hi PCM Programmer,
Thank for reply. My circuit operation is to read the eeprom after power up, so I put a delay for settling time. But the problem is why the circuit is working with use of "Delay_S(1);" function instead of using four "delay_ms(250)" built-in function. This may be bug but I am not sure.
Anyway, it will be the best without delay, so I will try to change the fuse setting and post the result.
Thank a lot,
Ako |
