Bug with configuration bits in PIC18F2520? |
Posted: Tue Sep 27, 2005 8:42 am |
CCS generates:
Configuration Fuses:
Word 1: 0800 NOIESO NOFCMEN INTRC_IO
Word 2: 1EE8 NOBROWNOUT NOWDT BORV27 PUT
Word 3: 8700 PBADEN CCP2C1 LPT1OSC MCLR
Word 4: 0041 STVREN DEBUG NOLVP XINST
Word 5: C00F NOPROTECT NOCPD NOCPB
Word 6: E00F NOWRT NOWRTD NOWRTC NOWRTB
Word 7: 400F NOEBTR NOEBTRB
According to data sheet: CONFIG2H
bit7-5 Unimplemented: Read as '0'
Hence my problem with the configuration never verifying correctly!
How can I work around this and force the correct Word 2 for this device? Is there a way to manually set configuration bits? |
Posted: Tue Sep 27, 2005 12:43 pm |
You didn't post your #fuses statement or your compiler version,
so I made the test file below, to try to get close to what you're doing.
I compiled it with PCH vs. 3.235. It gave the following Config bits:
Code: | Configuration Fuses:
Word 2: 0E10 NOBROWNOUT WDT128 NOWDT BORV27 PUT
Word 3: 8300 PBADEN CCP2C1 NOLPT1OSC MCLR RESERVED
Word 4: 0081 STVREN NODEBUG NOLVP NOXINST RESERVED
Word 7: 400F NOEBTR NOEBTRB |
If you have PCWH, it's possible that you could use the Device Editor
to fix the fuses. If not, I think you have to upgrade the compiler.
See this thread: http://www.ccsinfo.com/forum/viewtopic.php?t=24380
In the past, I've tried to override the #fuses settings with a #rom
statement, and I think I was able to get the override values into the
HEX file, but it didn't get picked up by MPLAB and ICD2. So it's not
a convenient solution.
Code: | #include <18F2520.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, PUT, NOBROWNOUT, NOLVP, BORV27, WDT128
Mark
Posted: Tue Sep 27, 2005 1:23 pm |
Quote: | In the past, I've tried to override the #fuses settings with a #rom
a convenient solution. |
If its in the hex file and you import the hex file it should get picked up by MPLAB. |
StuartH
Joined: 19 Aug 2005 Posts: 14 Location: W. Midlands, UK
Posted: Tue Sep 27, 2005 3:13 pm |
I've had problems with this device with the brownout voltage select not programming correctly. It didn't matter in my application so I just ignored it, although this fuse worked properly in a 4520.
I don't know if this is a CCS problem as much as a(nother) Microchip silicon problem with this device.
Interestingly, I just checked the Microchip site five minutes ago (to see if they've updated the silicon yet) and they now list the 18F2520 as a "Future Product" So how come I was able to buy a bucketload of the things from Farnell two months ago? And they list them as being in stock now. I'm reasonably sure that when I last looked, the status was "In Production" (the 4520 is). The plot thickens... |
Posted: Wed Sep 28, 2005 1:35 am |
aSorry. It's version 3.212 which I am happy with apart from this problem:
#device icd=true
#device adc=10
#fuses INTRC,PUT,NOWDT,DEBUG,NOLVP,MCLR,NOFCMEN,NOIESO,NOBROWNOUT,NOXINST
#use delay(clock=8000000) |
Generates:
Code: | Word 2: 1EE8 NOBROWNOUT NOWDT BORV27 PUT |
the "E" in the high byte which should be a zero which is causing the problem as the PIC by definition always returns a "0".
I also can't get the IDE to recognise the #device icd=true when I try and debug, it always insists on adding the line itself!
If these are fixed in the later version I guess I am going to have to bite the bullet and upgrade.
Thanks for you help with this, much appreciated. |
Posted: Wed Sep 28, 2005 11:46 am |
I created the following test program based on your posted code:
#device icd=true
#device adc=10
I compiled it with PCH vs. 3.235. Here are the fuses from the .LST file:
Word 1: 0900 NOIESO NOFCMEN INTRC
Word 2: 1E19 NOBROWNOUT NOWDT BORV20 NOPUT WDT32768
Word 4: 0000 NOSTVREN DEBUG NOLVP NOXINST RESERVED
Posted: Fri Sep 30, 2005 1:09 am |
It would appear it's fixed.
CONFIG2H
bit7-5 Unimplemented: Read as '0'!
From an early post: I also bought mine through Farnell in the UK. I usually us the 18F252 but the '0' part has a faster internal oscillator which I needed.
Thank you all |
