How to use A6 and A7 on 16f88
Ringo42
PostPosted: Thu Sep 29, 2005 5:57 pm     Reply with quote
I have a 16f88 and want to use A6 and A7 as inputs. I 'm setting up to use the internal osc using
#fuses intrc_io
but the lines
Button=input(PIN_A6);
if(button==0)
LSkipper-=10;
don't work (LSpipper never changes). A6 and A7 are both pulled high with a 10K and a switch pulls them low. The Pic never sees the switch closeure . A couple more switches on different pins work fine. Is there a setup that I'm missing somewhere?
Ringo
Ringo Davis
PostPosted: Fri Sep 30, 2005 1:33 am     Reply with quote
Post a complete (but short) test program and post your version of the
compiler.
