kam
Compiler errors...brain fart! |
Posted: Wed Sep 28, 2005 3:28 pm |
Hi all,
I have the following C code that compiles in "normal" C
char *useCaseData[][3] =
{"kam", "was", "here"},
{"brian", "was", "here"},
{"sammy", "was", "here"},
{NULL, NULL, NULL}
How would I do the above (if possible) using CCS?
I'm using version(s) PCH 2.234
The data will be const data...
I keep getting compile errors...
Any thoughts?
~Kam (^8* |
kam
hmmm....not exactly what I need... |
Posted: Wed Sep 28, 2005 4:01 pm |
The problem I have is that the elements of the array are not all the same size.
char array_Name[12][4] = {
"123", "456", "789", "abc",
"NAY", "TOY", "TYU", "ERD",
"LOT", "BAS", "ALL", "TEL"
DOES compile, but the issue is that my elements are not all the same size!
Now...I could adjust the array to something line [12][20] (20 being the max length of the string), but does this NOT waste space? Does the compiler allocate 12*20 or does it "look" at the elements and only use what it needs? (ie. the [20] is the LARGEST...)
Thoughts?
~Kam (^8* |
Mark
Posted: Wed Sep 28, 2005 4:23 pm |
In your terms it wastes the space. But, it does just what you told it to do. |
