Hardware RX/TX and SDO at same time on 18F4550 ?
Bart
PostPosted: Tue Sep 27, 2005 1:53 pm     Reply with quote
As on a 16F877 the RX (pin26) TX (pin25) and SDO (pin24) are on separated pins,
on the 18F4550 they are RX and SDO on the same pin26, TX on pin25
So, my question is :
Can I use RX/TX and SDO/SDI/SCK at the same time ?
Eventualy I don't need the RX.
Question is they :
can I use the TX only (what do I specify for the RX pin then in CCS ?)
(so pin 26 SDO becomes available for my MMC card)
Thanks.
I like Skype (www.skype.com), my username is BplotM
PostPosted: Tue Sep 27, 2005 2:30 pm     Reply with quote
The data sheet doesn't show that the hardware USART can be split.
It's all or nothing:
bit 7 SPEN: Serial Port Enable bit
1 = Serial port enabled (configures RX/DT and TX/CK pins as serial port pins)
0 = Serial port disabled (held in Reset)
If you want to use Tx only, you can do so, but it will have to be
a software UART.
Bart
PostPosted: Tue Sep 27, 2005 2:41 pm     Reply with quote
Can I use
pin 24 RC5/D+/VP and
pin 25 RC4/D-/VM
for the software UART if I don't need the USB ?
(so : #use rs232(baud=9600, xmit=PIN_C5, rcv=PIN_C4,stream=MODEM)
Do I need more to specify in CCS no to activate the USB ?
PostPosted: Tue Sep 27, 2005 2:59 pm     Reply with quote
USB is disabled by default, upon power-up, so you should be able
to use those pins for a soft UART.
Humberto
PostPosted: Tue Sep 27, 2005 3:19 pm     Reply with quote
You can use any I/O if you want to use Tx only with software UART as PCM Programmer
told you, but not RC5(Pin24) wich is only Digital Input.
You can use RC6(Pin25) but as you are going to use it as an output be aware that
this is an open colector type and needs a resistor tied to +5V.
PCM Programmer let me correct you once in five years !!! Mr. Green
This is true in 16F87x series.
but in 18F series
bit 5 SSPEN: Synchronous Serial Port Enable bit
1 = Enable Serial port and configures SCK, SDO, SDI and SS as serial port pins.
0 = Disables Serial port and configures this pins as I/O pins.
When enabled, these pins must be properly configured as input or outputs.
Best wishes,
Humberto
PostPosted: Tue Sep 27, 2005 3:26 pm     Reply with quote
Thank you for correcting me. I didn't move my eyes over to
the right side of the overview section and see the "Digital Input".
I should learn to read the data sheet better (or drink more coffee). Mr. Green
Humberto
PostPosted: Tue Sep 27, 2005 3:38 pm     Reply with quote
I guess almost the same frequently...
"I should learn to read the data sheet better (or drink less wine)". Shocked
Humberto
PostPosted: Tue Sep 27, 2005 3:46 pm     Reply with quote
This morning when I came in, I only put half a scoop of coffee
into the coffee maker because I wanted to cut back on it. Then
I later said to myself, "Gee, I feel tired this morning...".
So now I know not to do that. Mr. Green
Bart
PostPosted: Wed Sep 28, 2005 12:42 am     Reply with quote
Hey guys,
Thanks for the "Relaxed moment/coffee talk" Laughing Wink and also for the solution.
Bart
