jahan
Light Timer with Interrupts |
Posted: Fri Sep 23, 2005 3:31 pm |
I'm writing a simple code to practice using my INT's and TIMERS.
3 Push Bottons are connected to RB0, RB1, RB2
RB0 = Start Timer (turn LED ON for 2 minutes and then turn it OFF)
RB1 = Turn LED ON (permenant)
RB2 = Turn LED OFF (if LED is ON even if on TIMER).
compiler: PCB,PCM,PCH=3.223
Code: | #include <18F452.h>
#device adc=8
#fuses NOWDT,WDT128,XT, NOPROTECT, NOOSCSEN, NOBROWNOUT, BORV20, NOPUT, \
NOSTVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, \
NOCPB, NOEBTR, NOEBTRB
#define ON 1
#define OFF 0
#define INTS_PER_SECOND 25 // (4,000,000/(4*16*250*10)) = 25
// Global Variables
int8 seconds; // A running seconds counter
int8 int_count; // Number of interrupts left before a second has elapsed
void Lights(int stat) {
if (stat == ON)
output_high(PIN_A0);
output_low(PIN_A0);
#int_TIMER2
void TIMER2_isr() {
// timer 2 overflows (250->0), which is apx 25 times/Sec
if(--int_count == 0) {
++seconds;
if (seconds == 120) {
Lights(OFF);
disable_interrupts(INT_TIMER2);
} else {
int_count = INTS_PER_SECOND;
#int_EXT
EXT_isr() { // Timer switch
Lights(ON);
seconds = 0;
#int_EXT1
EXT1_isr() { // Light ON
Lights(ON);
#int_EXT2
EXT2_isr() { // Light OFF
Lights(OFF);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_2(T2_DIV_BY_16, 250, 10);
set_timer2(0);
setup_ccp1(CCP_OFF);
enable_interrupts(INT_EXT);
enable_interrupts(INT_EXT1);
enable_interrupts(INT_EXT2);
while (TRUE) {
Please give me feed back as if this is the best way of doing this using INT and TMR2?
Thankx in advance |
treitmey
Posted: Mon Sep 26, 2005 8:10 am |
1)I would not pass an int8 into light() function when a int1 would do
2)in an isr just set a flag or buffer data. Dont go calling all sorts of funtions. KEEP IT SHORT
3)in general if a function[[light()]] is that simple, you should do it inline to save a calling level.
4)So if you move the bulk of the code out of the isr then you would have a loop at the end of main that would do something like
- - - -I don't know if this will work, but i thnk you'll get my meaning.- - - -
#use delay(clock=16000000)
//#use delay(clock=4000000)
#define ON 1
#define OFF 0
// Global Variables
int1 light_on,timer_on; // Number of interrupts left before a second has elapsed
#int_TIMER2
void TIMER2_isr() {
++seconds;
#int_EXT
timer_on=TRUE;
#int_EXT1
light_on=TRUE;
#int_EXT2
light_on=FALSE;
setup_adc(ADC_OFF);
setup_wdt(WDT_OFF);
set_timer2(0);
while (TRUE) {
if(timer_on)
seconds = 0;
timer_on=false;
if(light_on)
if(!light_on)
output_low(PIN_A0);
if (seconds == 120)
light_on=false;
