miror byte
tophe59
miror byte
PostPosted: Sat Oct 15, 2005 12:26 pm     Reply with quote
hi,
is search simply methode to mirored a byte ex:
0b 0011 1011 ---> 0b 1101 1100
Thank's Very Happy
pirev
View user's profile Send private message Visit poster's website ICQ Number
PostPosted: Sat Oct 15, 2005 12:54 pm     Reply with quote
   Mirror byte for PIC12/14/16
   For PIC18 will not work
#bit _C=STATUS.0
#define _RLF_F(data) #asm rlf data,F #endasm
#define _RRF_F(data) #asm rrf data,F #endasm
int8 MirroByte(int8 value) {
int8 i,mirror;
   i = 8; mirror = 0;
   do {
      _RLF_F(value);
      _RRF_F(mirror);
   } while( --i );
   return mirror;
 For PIC18 change _RLF_F & _RRF_F to
#define _RLCF_F(data) #asm rlcf data,F #endasm
#define _RRCF_F(data) #asm rrcf data,F #endasm
PostPosted: Sat Oct 15, 2005 2:39 pm     Reply with quote
This is almost certainly a student-type question, which has been
answered before. So you can find it with the forum's search engine.
Just don't search for a word like "mirrored". Use more common
words in the search string, such as: Reverse bits
Then set it to "Search for all terms".
Here are some typical results. If you use the search engine
you can easily find the answers.
http://www.ccsinfo.com/forum/viewtopic.php?t=23356&highlight=reverse+bits
http://www.ccsinfo.com/forum/viewtopic.php?t=8375&highlight=reverse+bits
http://www.ccsinfo.com/forum/viewtopic.php?t=23364&highlight=reverse+bits
tophe59
PostPosted: Sun Oct 16, 2005 1:27 am     Reply with quote
Thank Pirev and PCM.
Next time i'll search before Wink
