Help with printf & PCH
eyewonder300
PostPosted: Tue Sep 20, 2005 7:15 pm     Reply with quote
I just migrated from a PIC 16F877A to a 18F4680, and programs didn't work, in the protions that wrote to a VFD display. I chassed it down to a problem when doing a printf with a float, where it clears my screen, or puts numbers in the wrong place.
If I take out the decimal point formatting of the "2.2%f", it does NOT clear the display & shows up in the correct position, and is (somewhat) acceptable.
Advice on how to achieve same results as with previous versions of CCS compilers will be appreciated.
CCS PCH C Compiler, Version 3.234
//   Fuel_x_1.c
#include <18f4680.H>
//#FUSES HS,NOPROTECT,NOWDT,NOBROWNOUT,NOLVP,NOCPD,NOWRT,DEBUG
#use delay(clock=10000000)
#use i2c(master,sda=PIN_C4,scl=PIN_C3,slow,force_hw)
//#define   ICD2
#ifdef   ICD2
   #reserve 0x70,0xF0,0x170
   #reserve 0x1E5:0x1F0
#include "noritake_fms_3x.h"
float float_1;
   vfd_init();
   vfd_putc("\fFuel Management System");
   vfd_gotoxy(1,2);
   vfd_putc("Fuel_X_1.c");
   delay_ms(5000);
   vfd_putc("\fPrintf function");
   vfd_gotoxy(1,2);
   vfd_putc("line 2  ");
   delay_ms(3000);
   float_1 = 32.1234;
   printf(vfd_putc,"%2.2f",float_1);  <== CLEARS DISPLAY & WRONG POSITION
//   Fuel_x_1.c
//#define   ICD2
#ifdef   ICD2
float float_1;
   vfd_init();
   vfd_gotoxy(1,2);
   delay_ms(5000);
   vfd_gotoxy(1,2);
   delay_ms(3000);
   float_1 = 32.1234;
   printf(vfd_putc,"%f",float_1); <<== OK display
Thanks,
Steve
PostPosted: Tue Sep 20, 2005 8:38 pm     Reply with quote
First thing, put a while(1); statement at the end of your program.
CCS puts a hidden sleep statement at the end of main(), and it's
better that you end your program in a way that you define, rather
than letting CCS do it.
2nd, your problem is caused by a bug in the CCS printf routine
for floating points. A few revisions ago, they tried to fix the
round-off bug. But they introduced new bugs, such as the one
you're seeing. The printf in your code is putting out a huge number
of space characters (0x20) before it prints the floating point value.
I think you should report this bug to CCS. I sent them several emails,
as each revision still had bugs in the printf floating point code.
Then they posted on their revisions page a revision that "will make
everybody happy". But even that one still has bugs. They didn't fix it.
So I just gave up. Maybe, if you send them an email with sample code,
and a full explanation, maybe they'll fix it ?
Here is demo program that shows a work-around for your problem.
Create a small routine that will filter out the leading spaces. Then feed
the output of your main printf statement to the filtered output routine.
Let the filter routine send chars to vfd_putc().
#include <18F4680.H>
my_putc(char c)
if(c != 0x20)
   printf(vfd_putc, "%c", c);
float float_1;
float_1 = 32.1234;
printf(my_putc, "%2.2f",float_1);
eyewonder300
PostPosted: Tue Sep 20, 2005 9:00 pm     Reply with quote
Thanks, PCM. Your work-around seems to be working. I will send in a bug-report to CCS & maybe they can correct this.
Steve
