d00dajo
| Bit_test function and pointers |
Posted: Tue Sep 20, 2005 1:46 am |
I have a problem using the bit_test function with pointers.
bit_clear and bit_set will both work perfectly, but the following:
int8 * myPtr;
myPtr = &(MyStruct[2].MyElement[6]);
if(Alpha)
bit_set(*myPtr,0); //OK
bit_clear(*myPtr,0); //OK
if(bit_test(*myPtr,0)) //NOT OK. Will return TRUE always!!!
So, it seems that compiler function bit_test will not work with pointers. I dont really see WHY the compiler does not have support for that, since it is stated that bit_test is the same as ((var & (1<<bit)) != 0) only more efficient. (*myPtr & (1 << bit)) != 0 should work perfectly.
Any suggestions?
//Daniel.[/code] |
d00dajo
| Addition. |
Posted: Tue Sep 20, 2005 1:54 am |
Addition:
((*myPtr & (1<<bitnr)) != 0)
This does work! |
Posted: Tue Sep 20, 2005 2:03 am |
You didn't give a full test program, so I made one.
This program works OK with PCM vs. 3.233.
It displays:
False
True
#include <16F877.H>
#use delay(clock = 4000000)
struct
int8 MyElement[10];
}MyStruct[4];
int8 *myPtr;
MyStruct[2].MyElement[6] = 0;
printf("True\n\r");
printf("False\n\r");
MyStruct[2].MyElement[6] = 0xFF;
printf("True\n\r");
d00dajo
| Problem resolved |
Posted: Tue Sep 20, 2005 2:24 am |
| PCM programmer wrote: | You didn't give a full test program, so I made one.
It displays:
False
True
Hi "PCM programmer",
Thank you for your assistance,
Yes, of course the bit_test function works perfectly with pointers. The problem was derived from a memory overallocation on my part.
//Daniel. |
