| IO Problem, Cannot Read Inputs |
Posted: Tue Sep 20, 2005 1:45 pm |
Im not sure what the problem is, but I cannot seem to read my IO pins.
I am using the PIC18F8490. I have an LCD connected (which I know works). I am just trying to change whats displayed to corresond to switch settings. It never changes. I have external pullups on all of the input pins. Any ideas?
#include "lcdboard.h"
PreLaunch();
Configure_IO();
Configure_Units(); // Read all switch setting, set defaults
while(1){
testIO();
void PreLaunch(){
setup_oscillator(OSC_31KHZ|OSC_INTRC);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
setup_vref(FALSE);
setup_spi(SPI_SLAVE);
setup_low_volt_detect(FALSE);
setup_lcd(0b10001001,0b01110000);
void Configure_IO() {
Set_TRIS_B(0x00);
Set_TRIS_C(0x00);
void TestIO(){
int value1 = 0;
int value2 = 0;
if (DIP1 == 0)
value1+=1;
if (DIP2 == 0)
value1+=2;
if (DIP3 == 0)
value1+=4;
if (DIP4 == 0)
value1+=8;
if (DIP5 == 0)
value1+=16;
if (DIP6 == 0)
value1+=32;
if (value1 > 29){
lcd_symbol(Digit_Map[3],DIGIT5);
lcd_symbol(Digit_Map[value1-30],DIGIT4);
else if (value1 > 19){
lcd_symbol(Digit_Map[2],DIGIT5);
lcd_symbol(Digit_Map[value1-20],DIGIT4);
else if (value1 > 9){
lcd_symbol(Digit_Map[1],DIGIT5);
lcd_symbol(Digit_Map[value1-10],DIGIT4);
else {
lcd_symbol(Digit_Map[value1],DIGIT4);
if (SW1 == 0)
lcd_symbol(Digit_Map[1],DIGIT8);
if (SW2 == 0)
lcd_symbol(Digit_Map[2],DIGIT8);
if (SW3 == 0)
Heres part of the .h file
#include <18F8490.h>
#device adc=10
#FUSES NOWDT //Watch Dog Timer uses 1:32 Postscale
#FUSES BORV28 //Brownout reset at 2.8V
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES NOMCLR //Master Clear pin enabled
#use delay(clock=32000)
#define SW1 PIN_B7
#define SW2 PIN_B6
#define SW3 PIN_B5
#define DIP1 PIN_B0
#define DIP2 PIN_B1
#define DIP3 PIN_B2
#define DIP4 PIN_B3
#define DIP5 PIN_B4
#define DIP6 PIN_C2
newguy
Posted: Tue Sep 20, 2005 1:52 pm |
| You have the tris set wrong. 0 = output, 1 = input. |
Mark
Posted: Tue Sep 20, 2005 1:59 pm |
PIN_B7 is #defined as a number
| Code: | #define PIN_B7 31759
that means something to CCS specific functions.
In your code:
would be
See the problem yet? You need to define DIP1 as portb.7 where you define portb as a variabe at the location of portb. Another option is to use the CCS function input(DIP1).
Also, if you handle the var yourself, remember to set the tris correctly (1 for an input). If you use standard_io and the CCS function, the Compiler will handle the tris for you. |
Posted: Tue Sep 20, 2005 2:29 pm |
| Thanks Guys, works now. |
