Eugeneo
Decoupling 3.3v to 5v |
Posted: Mon Sep 05, 2005 2:22 am |
I'm interfacing a M25P20 (2mbit cheap flash ram chip) and a pic 16LF819. The problem is my ICP is 5 volts so I need to decouple the flash chip from the power circuit, clock and data lines. Since there are all surface mount components, I can't just pull it off during programming. I've thought about dropping my ICP voltage to 3.3 but the programmer chip is not a low voltage device. Just so I can develop this thing, I've got jumpers on the board to completely disconnect it. For future is there any other options available that you guys could recomend? |
MikeValencia
Posted: Mon Sep 05, 2005 2:18 pm |
I once had a simple circuit where two AA batteries got me 3V. All I powered up was an LCD and a PIC. I used a self-powered ICD-2 to flash the PIC 16LFxxx chip.
The ICD-2 can use its own power from an adapter. Can't you directly program the PIC with a self-powered ICD-2? |
Posted: Mon Sep 05, 2005 2:37 pm |
That's the problem, my ICD doesn't function at 3 volts. But now that you mention it, finding an ICD that runs at 3v then self powering it, sounds like a great idea. As long as the charge pump puts out enough for MCLR. Or I guess I could go to LVP as well.
Thanks for you help |
kender
Eugeneo
Posted: Tue Sep 06, 2005 1:33 am |
Very helpful, thanks you for that. |
