racerx
serial write to gu128x64-330 noritake VFD? |
Posted: Tue Aug 30, 2005 4:54 pm |
I have been trying to write serially to a noritake GU128x64-330 display.
the default mode to talk is
19.2k, even parity.
information removed, because I was an idiot to post without it right in front of me.
please see below for correct information.
thank you pcm for pointing to the correct spec.
Posted: Tue Aug 30, 2005 6:19 pm |
Quote: | I have been trying to write serially to a noritake gui128x64-330 display. |
Is that part number accurate ?
The search engine on the Noritake website doesn't find it.
Goggle doesn't find it.
Is it really gu128x64-330 ? (ie., with no "i" after the "gu")
If so, Noritake is one of those companies that won't give out the
data sheet. However, an alternate site appears to have it.
http://www.elektronica-it.com/Itron/
Is this the data sheet you're using:
http://www.elektronica-it.com/Itron/GU128X64-330_E01.pdf
If so, I don't see the command sequence that you specified in your
post, given in the data sheet. What page of the data sheet shows
that sequence ? |
racerx
Posted: Tue Aug 30, 2005 6:53 pm |
sorry, yes that is the correct part number. On page 3 they talk about the character write mode. On page 12 they talk about the serial write timing.
I can post the source code in the morning, the code above is off the top of my head.
thanks |
Posted: Tue Aug 30, 2005 7:19 pm |
Quote: | the code above is off the top of my head. |
Grrrr....
Next thread. |
racerx
Posted: Wed Aug 31, 2005 6:10 am |
sorry, no code off top of head ever again!
here is the lcd only portion:
#include <16f88.h>
#fuses HS,NOLVP,NOWDT,PUT,MCLR
#use rs232(baud=19200, xmit=PIN_A4, parity=e, stream=LCD)
#use rs232(baud=38400, xmit=PIN_B5, rcv=PIN_B2, parity=n, stream=PORT)
#define WR PIN_A2 // output RED/WRITE
#define RESET PIN_A3 // output WHITE/RESET
#define SIN PIN_A4 // output ORANGE/Serial IN
#define BUSY PIN_B0 // input BLUE/BUSY
#byte PORT_B = 0x06
#byte ANSEL = 0x9B
main()
/* init registers */
set_tris_a(0b11100010); // RA1 not used, RA0, RA4:2 output, RA5 = mclr , RA7:6 OSC
set_tris_b(0b11011111); // port b all input, RB5 tx out
ANSEL = 0x00; // disable all A/D and make them digital I/0
// reset the display by bringing the reset line low
output_low(RESET);
delay_ms(10);
output_high(RESET);
delay_ms(210); //wait 210 mS for display to fully power back up
// write to the display
output_low(WR);
fprintf(LCD, "\x01\x43");
fprintf(LCD, "\x00\x01");
fprintf(LCD, "SR");
output_high(WR);
Posted: Wed Aug 31, 2005 9:14 am |
What you post in neither case agrees with what you say the unit needs. The sequence:
fprintf(LCD,"\x01\x43\x52\x01\x72");
sends 01+<C>+<R>+01+<r>
not the 'CS' you say is needed. Similarly on the latter code, you send:
01+<C>+00+01+<S>+<R>
Try:
fprintf(LCD,"\x01CS\x01r");
Also if you want to control the TRIS lines, switch to using fast_io, otherwise the settings you make will be overridden as soon as you do an I/O instruction.
racerx
Posted: Wed Aug 31, 2005 11:16 am |
from the spec exactly:
8.2 Structure of data block
A data block consists of "Header", "Op code" and "Data".
"Header" + "Op code" + "Data"
01HEX 1Byte
"Header": 01HEX
"Op Code" : Operation code which specify a type of "Data" such as Graphics, charater and command.
"Data" : Data block
8.3 Op code
8.3.1 Charater Write
Op code: "C"
Format
01HEX + "C"(43HEX) + Start ADRS (1Byte) + LEN(1Byte) + Write Mode(1Byte) + chr(1) + chr(2) + ... + chr(LEN)
so I try to send R to the lcd on line one at Adrs 00
fprintf(LCD, "\x01C\x00\x01SR");
so if I echo this command to minicom, I only get .C back from the fprintf, and not the .CSR that I think I should get. |
Mark
Posted: Wed Aug 31, 2005 11:36 am |
add a while(1) to the bottom of your main. The way you have it, it hits a hidden sleep instruction after main before the uart is finished transmitting. |
racerx
Posted: Wed Aug 31, 2005 12:35 pm |
the fprintf command bombs out if you try to send \x00 for the address, perhaps there is some kind of internal parsing occuring with it?
i use \x01 and bam the charater is on the screen!
#include <16f88.h>
//#use rs232(baud=38400, xmit=PIN_B5, rcv=PIN_B2, parity=n, stream=PORT)
#byte PORT_B = 0x06
#byte ANSEL = 0x9B
main()
set_tris_a(0b11100010); // RA4:2 output, RA5 = mclr , RA7:6 OSC
output_low(RESET);
delay_ms(10);
output_high(RESET);
delay_ms(210); //wait 2 seconds for display
fprintf(LCD, "\x01C\x01\x01SR");
Mark
Posted: Wed Aug 31, 2005 1:21 pm |
I don't believe that you can send 0 (null) with a printf command. That usually signifies the end of a string. |
racerx
Posted: Wed Aug 31, 2005 1:53 pm |
is there a command to do serial out like serout or serout2 in picbasic? |
Mark
Posted: Wed Aug 31, 2005 2:31 pm |
putc() |
