Decoupling 3.3v to 5v
Eugeneo
PostPosted: Mon Sep 05, 2005 2:22 am     Reply with quote
I'm interfacing a M25P20 (2mbit cheap flash ram chip) and a pic 16LF819. The problem is my ICP is 5 volts so I need to decouple the flash chip from the power circuit, clock and data lines. Since there are all surface mount components, I can't just pull it off during programming. I've thought about dropping my ICP voltage to 3.3 but the programmer chip is not a low voltage device. Just so I can develop this thing, I've got jumpers on the board to completely disconnect it. For future is there any other options available that you guys could recomend?
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Mon Sep 05, 2005 2:18 pm     Reply with quote
I once had a simple circuit where two AA batteries got me 3V. All I powered up was an LCD and a PIC. I used a self-powered ICD-2 to flash the PIC 16LFxxx chip.
The ICD-2 can use its own power from an adapter. Can't you directly program the PIC with a self-powered ICD-2?
PostPosted: Mon Sep 05, 2005 2:37 pm     Reply with quote
That's the problem, my ICD doesn't function at 3 volts. But now that you mention it, finding an ICD that runs at 3v then self powering it, sounds like a great idea. As long as the charge pump puts out enough for MCLR. Or I guess I could go to LVP as well.
Thanks for you help
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Mon Sep 05, 2005 6:01 pm     Reply with quote
Here's a monologue on the subject, which might be useful:
http://www.ccsinfo.com/forum/viewtopic.php?t=20395
Eugeneo
PostPosted: Tue Sep 06, 2005 1:33 am     Reply with quote
Very helpful, thanks you for that.
