I tried to use PIC18F2331 with 25MHz crystal with 22pF capacitors, and configure as HS, but the program cannot run, can someone help me on this?
Thanks a thousand if anyone reply....
asmallri
Joined: 12 Aug 2004 Posts: 1640 Location: Perth, Australia
Posted: Wed Aug 31, 2005 3:07 am
Opps - did not pay attention to the details. No this chip cannot use a 25MHz crystal. It can use a 25MHz oscillator. It can also use a lower speed crystal and the internal x 4 multiplier to give 40MHz. _________________ Regards, Andrew
