JGoodman
lcd.c limitation |
Posted: Mon Aug 29, 2005 7:00 am |
I may just be doing something wrong, but it seems like the lcd.c library which ccs provides is somewhat limited. I can only ouput characters that I type into the function call e.g. lcd_putc("Hello"). It does not seem like I can send strings or variables to this function e.g. char bob[6]="hello"; lcd_putc(bob);
Any advice?
-Thanks. |
Mark
Posted: Mon Aug 29, 2005 7:18 am |
Did you even look at what the parameter for lcd_putc() is????? If you want to pass something else, write your own function or wrap the function inside another. you can also use the printf function with lcd_putc
char *pointer;
pointer = bob;
while (*pointer)
lcd_putc(*pointer);
pointer++;
printf(lcd_putc,"Hello");
printf(lcd_putc,"%S",bob); |
JGoodman
Posted: Mon Aug 29, 2005 7:49 am |
Thank you very much, that did the trick!
J G |
