7-segments with DS1307
newpic
PostPosted: Fri Aug 26, 2005 7:26 am     Reply with quote
Hello to everyone,
Does anyone know of a method in which I can use to send the
information received from a DS1307 RTC into their individual digits, so
that I can place these digits on their respective 7-Segment Led Displays.
I have four 7-Segment Led displays and would like to display the time on
these. But I don't know how to single out the individual digits after the
information is received from the DS1307.
Any advice or suggestions would be grately appreciated.
I am limit to C and PIC, If you could give more detail or example code
would be gradely appreciated.
Mark
PostPosted: Fri Aug 26, 2005 8:39 am     Reply with quote
Hum... as I recall the data is BCD so it should be easy. Each nibble would be a digit.
PostPosted: Fri Aug 26, 2005 9:18 am     Reply with quote
Any simple example?
Thanks..
Mark
PostPosted: Fri Aug 26, 2005 11:56 am     Reply with quote
There is already code posted for DS1307. That code will allow you to read the registers from the DS1307. We have no idea how you are driving your 7 segment LEDs but if you know how to display a number then it should be trivial to display the time.
PostPosted: Fri Aug 26, 2005 11:57 am     Reply with quote
Just do a web search with http://www.google.com for this string:
ds1307 CCS segment OR segments
http://www.rentron.com/CCS_C/SERLED_C.htm
Source code for this one is at the bottom of the page:
http://www.sixca.com/eng/articles/clock/
