skyforme
How can I read in this mode - AD conv. SEQM2 |
Posted: Wed Aug 24, 2005 11:01 am |
Hello
I want to read four samples if interrupt occurs.
But it always read the same strange thing.
int16 value1,v2,v3,v4;
// This function turns the LEDs on and off
void flash_led() {
output_low(TOGGLE_PIN);
delay_us(value1*10);
output_high(TOGGLE_PIN);
#int_AD
AD_isr()
set_adc_channel(1);
value1 = Read_ADC(ADC_READ_ONLY);
set_adc_channel(0);
v2 = Read_ADC(ADC_READ_ONLY);
set_adc_channel(6);
v3 = Read_ADC(ADC_READ_ONLY);
set_adc_channel(7);
v4 = Read_ADC(ADC_READ_ONLY);
//value = Read_Adc();
flash_led();
// Start the initial conversion
Read_ADC(ADC_START_ONLY);
setup_adc_ports(sAN0|sAN1|sAN2|sAN3|sAN4|sAN5|sAN6|sAN7|sAN8|VSS_VDD);
setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_0|ADC_CONT_A_B_C_D|ADC_INT_EVERY_FOUR);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
enable_interrupts(INT_AD);
setup_low_volt_detect(FALSE);
setup_oscillator(False);
output_high(PIN_D1);
output_high(PIN_D2);
output_high(PIN_C0);
It's the code..
but it alwyas shows the same thing and blinking the LED with strange rate (not pot reference).
Thank you |
Posted: Thu Aug 25, 2005 2:50 am |
The largest value that 'delay_us' can accept from a variable is 255. You are therefore seeing wrapping of the counter, giving variable length delays as the ADC changes. Use something like:
void flash_led() {
int16 ctr;
for (ctr=0;ctr<value1;ctr++) delay_us(5);
Depending on your clock rate, the delay will need to be shorter to allow for the time to do the arithmetic on the counter, and the test, but the results should then give a growing delay with larger ADC values.
