Software uart baud rate change
mcisabel
PostPosted: Fri Aug 19, 2005 8:18 am     Reply with quote
Hi, I had a problem, I'm working with two software uart and I would like to change the baud rate when I want doing a #use rs232 with a diferent baud rate but in the same stream that I allready had, but it doesn`t work and I don`t understand why.
#use rs232 (baud=9600, xmit=TX1, rcv=RX1, STREAM=COM_A, disable_ints) //PIC USART (AL PLC)
#use rs232 (baud=9600, xmit=TX2, rcv=RX2, STREAM=COM_B, disable_ints) //RS-232 maestro
#use rs232 (baud=9600, xmit=TX3, rcv=RX3, STREAM=COM_C, disable_ints) //RS-232 TTL al radio modem
#use rs232 (baud=9600, xmit=TX4, rcv=RX4, STREAM=COM_D, disable_ints) //RS-485
void uart_speed(char s, int puerto)
if(puerto==2)
if(s=='1')
delay_cycles(1);
#undef COM_B
#use rs232 (baud=19200, xmit=TX2, rcv=RX2, STREAM=COM_B, disable_ints
setting_uarts_speed(2);
enable_interrupts(INT_RB);
ext_int_edge(0,H_TO_L);
clear_interrupt(int_ext);
enable_interrupts(int_ext);
port_b_pullups(true);
while(mantente==0)
ALFA 705
PostPosted: Sat Aug 20, 2005 5:53 am     Reply with quote
Hola,
Try to use: set_uart_speed (baud, [stream])
That's :
set_uart_speed(19200,COM_A);
set_uart_speed(9600,COM_B);
You can change uart speed on each "COM".
I hope this can help you.
Salud !
ALFA 705
PostPosted: Sat Aug 20, 2005 6:53 am     Reply with quote
ALFA 705 wrote:
Hola,
That's :
Salud !
ALFA 705
No.
Look carefully at the manual entry. Note 'only applies to devices with the hardware UART' (should really say 'only applies to the hardware UART'...).
You cannot use 'set uart speed' on a software UART.
The problem is trying to be a bit 'too smart' in the original code. The USE RS232 command, creates the code for a software UART 'inline' when this is used. Unfortunately, this means you cannot switch 'on the fly'. Instead use something like this:
#use rs232 (baud=19200, xmit=TX2, rcv=RX2, STREAM=COM_BFAST, disable_ints) //RS-232 maestro at 19200bps
#define 9600bps (0)
#define 19200bps (1)
int8 speed=9600bps;
#define soft_set_speed(rate) speed=rate
void putc_comb(char s) {
   switch (speed) {
   case 9600bps:
      fputc(COM_B,s);
   case 19200bps:
     fputc(COM_BFAST,s);
   //expand for more rates if needed
soft_set_speed(9600bps);
printf(putc_comb,"Sent at 9600bps");
soft-set_speed(19200bps);
printf(putc_comb,"Sent at 19200bps");
