PORT_B_PULLUPS problem
Jerry Finsen
PostPosted: Sat Mar 01, 2003 7:14 pm     Reply with quote
I am trying to set the Port B Pull to TRUE and my program consistently hangs. Below is a minimum code segment that displays this. The printf displays if the pullup statement is commented out. Make it active and the nothing and it hangs.
I am using 3.146 under W2K and running on a meLabs X1 board. Equivalent code using PicBasic Pro works fine.
#include <16F877.h>
#fuses HS,NOWDT
#use RS232(baud=9600, parity=n, bits=8, xmit=PIN_C6, rcv=PIN_C7)
setup_adc_ports(NO_ANALOGS);
// port_b_pullups(TRUE);
printf("\fStart Test #3 ");
___________________________
Original Post ID: 12262
sar
Re: PORT_B_PULLUPS problem
PostPosted: Sat Mar 01, 2003 9:01 pm     Reply with quote
<font face="Courier New" size=-1>Try this:
#include <16F877.h>
#use delay(clock=4000000) //change to 20000000 for your app
#fuses XT,PUT,BROWNOUT,NOWDT //change to HS for your app
#include stdio.h
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, BITS=8 )
void display();
setup_adc(ADC_CLOCK_DIV_2);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
display();
void display()
printf("fStart Test #3\r\n ");
delay_ms (1000);
Will printf once a second with port_b_pullups active TRUE.
SAR</font>
Original Post ID: 12263
sar
PostPosted: Sat Mar 01, 2003 9:08 pm     Reply with quote
<font face="Courier New" size=-1></font>
Original Post ID: 12264
sar
PostPosted: Sat Mar 01, 2003 9:10 pm     Reply with quote
Original Post ID: 12265
PostPosted: Sat Mar 01, 2003 11:58 pm     Reply with quote
:=I am trying to set the Port B Pull to TRUE and my program consistently hangs. Below is a minimum code segment that displays this. The printf displays if the pullup statement is commented out. Make it active and the nothing and it hangs.
:=#fuses HS,NOWDT
:=void main() {
:= setup_adc_ports(NO_ANALOGS);
:=// port_b_pullups(TRUE);
:= printf("\fStart Test #3 ");
Add NOLVP to the fuses statement. This will cure the
problem of hanging when pullups are enabled. Example:
#fuses HS, NOWDT, NOLVP
You also have another problem, where the last two characters
in your printf() are cut off. You've tried to cure it by
adding two spaces at the end. You don't need to do that.
Instead, add a while(1) loop as the last statement in main().
This will prevent your program from falling off the end of
main(), and hitting the hidden SLEEP instruction that CCS
puts at the end of main().
The SLEEP instruction puts your PIC to sleep while it's still
got your last two chars queued up inside the USART transmitter.
Example:
printf("\fStart Test #3\n\r"); // Don't need trailing spaces
while(1); // Prevent PIC from going to sleep
Original Post ID: 12268
Jerry Finsen
PostPosted: Sun Mar 02, 2003 7:02 am     Reply with quote
:=Add NOLVP to the fuses statement. This will cure the
:=problem of hanging when pullups are enabled. Example:
Bumping my way through the learning curve...
jerry
Original Post ID: 12272
