16F876 & SHT71
mce91
16F876 & SHT71
PostPosted: Thu Aug 18, 2005 4:15 pm     Reply with quote
Hello
I has fought for 2 days to make the calculation of the CRC between a SHT71 and a PIC16F876.
Even with the scope note from sensirion I do not arrive there Crying or Very sad
http://www.sensirion.com/images/getFile?id=80
The calculation of the CRC at sensirion is not standard. I found at DALLAS a scope note (27) which uses the same principle but within sight of the table of CRC from Dallas the result is different.
My crontrainte is not to be able to use a table of CRC (no more place available)
If you have ideas or solutions I am taking
Michel
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
Re: 16F876 & SHT71
PostPosted: Thu Aug 18, 2005 4:20 pm     Reply with quote
Michel
If that is your only problem, then go upgrade your PIC16F876 to a PIC18F252. You'll now have double the space.
mce91
Re: 16F876 & SHT71
PostPosted: Thu Aug 18, 2005 4:33 pm     Reply with quote
MikeValencia wrote:
Michel
using another PIC is not the solution ...
mce91
16F876 & SHT71
PostPosted: Fri Aug 19, 2005 5:21 pm     Reply with quote
After lot of hours ... the solution by my self !!! Very Happy
unsigned int8 crc_sht (char *data,unsigned char oldcrc, unsigned int8 length)
unsigned int8 i=0, ibit=0, c=0, crc;
#bit crc4 = crc.4
#bit crc5 = crc.5
#bit crc7 = crc.7
#bit c7 = c.7
crc=oldcrc;
data++;
for (i = 0; i < length; i++, data--)
c = *data;
for (ibit = 0; ibit < 8; ibit++)
if (c7 == crc7)
crc = crc << 1;
crc = crc & 0xFE;
crc = crc << 1;
crc4 = ~(crc4) ;
crc5 = ~(crc5) ;
crc = crc | 0x01;
c = c << 1;
return crc;
