ASM RAM command to CCS
skyforme
PostPosted: Fri Aug 19, 2005 11:32 am     Reply with quote
Hello.
This is a sample code.
group2 udata_acs ;Declaration of group2 data. The
;addresses for data under this
;secton are allocated
;automatically by the linker.
=> How can I declare label?
group2_var1 res 1 ;All addresses be will allocated
group2_var2 res 1 ;in access RAM space only.
=> what can I use instead of res?
I think that #BYTE is different from res.
And I also found that I cannot use those command inside #ASM,#ENDASM.
How can I implement those commands?
Thank you
PostPosted: Fri Aug 19, 2005 11:45 am     Reply with quote
Look in the Readme.txt file for the latest version of the compiler. (3.231)
See the explanation of the new typemod and #type directives
which allow you to allocate a block of variables to a specified
address range of RAM.
The Readme.txt file is in this folder: c:\Program Files\Picc
