runtime
level shifting between 3.3V and 3.6V |
Posted: Wed Aug 17, 2005 10:50 am |
Hello All,
I would like your help on the following:
I have to connect a 3.6V device to a PIC(PIC18F252) at 3.3V, the manual for the 3.6V device says I can use a diode/resistor level shifting for this.
There is an image that shows a schematic circuit with a 4.7K resistor and a shotky diode, what would be the value for this diode? any shotky diode will do?
Thank you in advance
Peter |
eaton2 Guest
Posted: Wed Aug 17, 2005 11:25 am |
Without seeing the circuit i can't tell you any particulars but the voltage drop across a schottky is nominally .3V. I would imagine the 4.7K is used as a current limiter |
asmallri
Re: level shifting between 3.3V and 3.6V |
Posted: Fri Aug 19, 2005 1:44 am |
runtime wrote: | Hello All,
Peter |
I assume you mean you are using a PIC18LF252 not a PIC18F252. The easiest way to solve this would be to run the PIC at 3.6volts. If for some reason you cannot then there are a couple of simple ways you can go about this.
Method one (diode forward volt drop):
Device output to PIC input
Cathode of Shottky diode to PIC
Anode of Shottky diode to Device
4K7 resistor from Cathode to ground
PIC output to device input - directly connected.
Method two (voltage divider method)
390R resistor from Device output to PIC input
4K7 resistor from PIC input to ground
PIC output to device input - directly connected. _________________ Regards, Andrew
