12F629 Issue with output_toggle()
PostPosted: Tue Aug 16, 2005 12:13 pm     Reply with quote
I have a problem with the output_toggle() function working within a IF{} statement. When i move into the while() loop it toggles the correct GPIO pin. Any suggestgion would help
Here is the copy of the code
Thanks KMAC
* Default_Reset.c  - This code will allow the user to reset the short range  *
*                    radio to its default settings.                          *
* Functions:    void detect_ra_change() - This allows to see the pushbutton  *
*                                         interrupt                          *
*               void clear_delta() - Presets the value of Reset Interrupt    *
*                                    flag                                    *
*               void Toggle_LED()  - This function toggles the DONE LED      *
*                                    On and Off                              *
*  Author: Kevin McClure  copyright (c) 2005 Cooper Power Systems            *
#include <12F629.h>
#fuses  NOWDT, INTRC_IO, NOCPD, NOPROTECT, MCLR, PUT, NOBROWNOUT
//  Time and Logic  and Interrupt Defines
#define LOWTOHIGH TRUE
#define HIGHTOLOW FALSE
#define Debounce_Delay  100
#define delay_time_1sec 1000
#define delay_time_2sec 3000
short int dbutton0;
#int_ra
// pin definitions
#define PDAT            PIN_A0     // programming pin
#define PCLK            PIN_A1     // programming pin
#define UUT_PWR         PIN_A2     // UUT Power Pin
#define MCLR            PIN_A3     // MCLR reset input
#define DEFAULT_SET     PIN_A4     // Default Set Pin
#define DONE_L          PIN_A5     // Done Indication LED
*  void detect_ra_change()  - This function detects the change   *
*                             in RA0 and sets the correct value  *
*                             Variable dbutton1 dependent of the *
*                             value of RA0                       *
   int current;
   static int last=0;
   set_tris_A(0x0B);   // Sets the status of the I/O pins
   current=input_A();  // Sets current to the value of the GPIO register
   //test the value bit 0 (GPIO 0) to see if it is TRUE
   #if LOWTOHIGH
   if ((!bit_test(last,0))&&(bit_test(current,0))) {dbutton0=1;}
   //test the value bit 0 (GPIO 0) to see if it is FALSE
   #elif HIGHTOLOW
   if ((!bit_test(current,0))&&(bit_test(last,0))) {dbutton0=1;}
   last=current;
*                       On and Off                               *
void Toggle_LED()
output_toggle(DONE_L);
*  void clear_delta() - This function clears and defalts set the *
*                       Reset interrupt flag value to 0          *
void clear_delta()
         dbutton0=0; //Sets the default value to 0
*   Start of Main Function                                       *
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
 clear_delta();              // Clears the Reset Interupt Flag
 output_low(DEFAULT_SET);    // De-Asserts the DEF signal
 output_high(UUT_PWR);       // energizes the UUT
          delay_ms(Debounce_Delay);              // (Needs 1 sec Debounce)
          enable_interrupts(INT_RA0);           // Enable GPIO 0 Interrupt
          enable_interrupts(GLOBAL);           // Enable Global Interrupts
          if(dbutton0==1)
               disable_interrupts(GLOBAL);      //Disables All Interrupts
               Toggle_LED();                    // Calls the Function to Toggle the DONE LED
               output_low(UUT_PWR);             // De-energizes the UUT
               delay_ms(delay_time_1sec);       // 2 Second Delay
               output_high(DEFAULT_SET);        // Asserts the DEF Signal
               delay_ms(delay_time_2sec );      // 2 Second Delay
               output_high(UUT_PWR);             // Renergizes the UUT
                delay_ms(delay_time_2sec);       // 2 Second Delay
               output_low(DEFAULT_SET);         // De-Asserts the DEF Signal
               output_low(DONE_L);              // Set the DONE LED to ON
               output_high(DONE_L);             // Sets the deone LED to OFF
               dbutton0 =0;                     // Resets the push button flag
               enable_interrupts(GLOBAL);       // Re-enables the interupts
               }// End of If Statement
        }// End of While Statement
}// End Of Main
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Tue Aug 16, 2005 12:52 pm     Reply with quote
#byte port_a=0x{porta's address}
port_a ^= 0x20; // 0010 0000
This is an alternative way to toggle, which is merely doing an XOR on bit 5.
I did not quite read into your code to see if there is something wrong with your program's flow, but you can try the above statement in place of that toggle library function and see what happens.
