CAN and 18f258
troky2001
CAN and 18f258
PostPosted: Wed Aug 10, 2005 2:45 pm     Reply with quote
Hi all,
I am trying to make CAN message sniffer based on 18f258 and max13050 can interface.
I am using example code from PICC 3.227 adjusted to work at 40MHz but still can't see any messages.
My baud settings are (500kbps):
BRGCON1=0x03;
BRGCON2=0x98;
BRGCON3=0x03;
Are these values ok? Should I change anything else in source expect #delay...?
Thanks,
Troky
PostPosted: Wed Aug 10, 2005 3:39 pm     Reply with quote
Read this thread for information on how to choose and configure
CAN bus bit timing parameters:
http://www.ccsinfo.com/forum/viewtopic.php?t=22138
The CCS drivers are setup to accept Extended IDs.
Does the system that you're monitoring use Extended IDs or Standard IDs ?
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=20387&highlight=extended+standard
troky2001
PostPosted: Thu Aug 11, 2005 3:28 pm     Reply with quote
Thanks for tips. I'll try tomorrow and post results.
