Problem whit ICd-u40 NO connect
Roberto da Rivoli
PostPosted: Fri Aug 05, 2005 1:05 am     Reply with quote
good day I have a problem with ICD-u40 I have loaded the last version to firmware and I worked correctly. the successive day the device comes seen from the PC and with tool the ICD connection setting they give the error to me "could not connect: NOT response from ICD"
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Tue Aug 09, 2005 10:25 am     Reply with quote
I have this problem too. In my case it happens when I try to pump a lot of debug data through the ICD. I have found that if you unplug the ICD from the USB and then connect it back, it will start responding again.
Another thing is that you can not have the ICD probram and the debugger inside the compiler running at the same time.
