RAM problem
leto
RAM problem
PostPosted: Mon Aug 08, 2005 2:45 pm     Reply with quote
My program has a "not enough RAM for all variables". But just when I put a comment "//" in char k definition (1st of main) instead of when I get out this comment. I guest when i put a comment im releasing memory but it has an opposite behavior.
Could anyone help me.
//   char k;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   SET_TRIS_A( 0x00 );           // All A are outputs
   SET_TRIS_B( 0xFF );           // B7,B6,B5,B4,B4,B2,B1 are inputs
   rtc_init();
   set_clock();
   init_ext_eeprom();
   port_b=0;
   seconds=0;
   minutes=0;
   setup_counters(RTCC_INTERNAL, RTCC_DIV_256 );
   set_rtcc(236);
   ext_int_edge(L_TO_H);
   enable_interrupts(INT_RB);
   enable_interrupts(global);
   port_b_pullups(FALSE);
   glcd_init(ON);
   while (TRUE);
Page ROM  %  RAM  Functions:
0      19   0   1  @delay_ms1
1    121   2   1  glcd_init
1    150   3   9  glcd_pixel
1    106   2   4  glcd_fillScreen
1      39   1   2  @MUL88
0      50   1   2  glcd_writeByte
1      60   1   2  glcd_readByte
0    235   4   0  @const71
0    235   4   0  @const74
0      42   1   0  @const77
0    262   5   0  @const80
0    227   4   0  @const83
1      23   0   5  @MUL1616
1    219   4  20  glcd_text57
1    404   7  58  glcd_myText
0      18   0   1  @I2C_WRITEU_1_59_60_20000000
1      17   0   1  @I2C_READU_1_59_60_20000000
0      13   0   0  init_ext_eeprom
1      49   1   5  read_ext_eeprom
0      14   0   0  @const10575
0      23   0   3  @DIV88
1    129   2   6  @PRINTF_D_9600_62_63
0      94   2   0  @const220
0      28   1   0  @const223
0      42   1   0  @const226
1      10   0   1  @SPRINTF
1    117   2   6  @PRINTF_D_458
1      94   2   8  @PRINTF_LU_458
2   1148  21   4  MainMenu
0      26   0   0  @const10818
0      25   0   0  @const10822
1      63   1   4  Menu2
1    104   2   4  MenuSelect
0        6   0   0  @const10873
0      29   1   0  @const10899
0      26   0   0  @const10907
1      35   1   8  i2c_eeprom_ReadString
0      30   1   2  write_ds1302_byte
0      19   0   2  write_ds1302
0      90   2   2  rtc_init
0      23   0   3  bin_to_bcd
0    101   2   7  set_clock
0      14   0   0  crono
0      46   1   0  tecla
0    127   2   4  external
0      13   0   0  @const11069
0      22   0   0  TiempoSector
2    481   9  22  welcome
0      23   0   0  @const11102
0      20   0   0  @const11106
0      14   0   0  @const11111
0      11   0   0  @const11126
0      13   0   0  @const11134
1    110   2   1  main
1      42   1   0  KeyPress
PostPosted: Tue Aug 09, 2005 12:48 pm     Reply with quote
I think no one has answered your post because we think it's
probably the same answer that's been posted 1000 times already.
But anyway, here's the likely answer:
The compiler doesn't normally use all the RAM banks with the PCM
compiler. You have to tell it to use RAM at addresses above 0xFF.
This is done by adding the #device *=16 statement, as shown below.
It should be placed in the next line after your main #include statement.
Example:
#include <16F877.h>
#device *=16
