leto
| RAM problem |
Posted: Mon Aug 08, 2005 2:45 pm |
My program has a "not enough RAM for all variables". But just when I put a comment "//" in char k definition (1st of main) instead of when I get out this comment. I guest when i put a comment im releasing memory but it has an opposite behavior.
Could anyone help me.
// char k;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
SET_TRIS_A( 0x00 ); // All A are outputs
SET_TRIS_B( 0xFF ); // B7,B6,B5,B4,B4,B2,B1 are inputs
rtc_init();
set_clock();
init_ext_eeprom();
port_b=0;
seconds=0;
minutes=0;
setup_counters(RTCC_INTERNAL, RTCC_DIV_256 );
set_rtcc(236);
ext_int_edge(L_TO_H);
enable_interrupts(INT_RB);
enable_interrupts(global);
port_b_pullups(FALSE);
glcd_init(ON);
while (TRUE);
Page ROM % RAM Functions:
0 19 0 1 @delay_ms1
1 121 2 1 glcd_init
1 150 3 9 glcd_pixel
1 106 2 4 glcd_fillScreen
1 39 1 2 @MUL88
0 50 1 2 glcd_writeByte
1 60 1 2 glcd_readByte
0 235 4 0 @const71
0 235 4 0 @const74
0 42 1 0 @const77
0 262 5 0 @const80
0 227 4 0 @const83
1 23 0 5 @MUL1616
1 219 4 20 glcd_text57
1 404 7 58 glcd_myText
0 18 0 1 @I2C_WRITEU_1_59_60_20000000
1 17 0 1 @I2C_READU_1_59_60_20000000
0 13 0 0 init_ext_eeprom
1 49 1 5 read_ext_eeprom
0 14 0 0 @const10575
0 23 0 3 @DIV88
1 129 2 6 @PRINTF_D_9600_62_63
0 94 2 0 @const220
0 28 1 0 @const223
0 42 1 0 @const226
1 10 0 1 @SPRINTF
1 117 2 6 @PRINTF_D_458
1 94 2 8 @PRINTF_LU_458
2 1148 21 4 MainMenu
0 26 0 0 @const10818
0 25 0 0 @const10822
1 63 1 4 Menu2
1 104 2 4 MenuSelect
0 6 0 0 @const10873
0 29 1 0 @const10899
0 26 0 0 @const10907
1 35 1 8 i2c_eeprom_ReadString
0 30 1 2 write_ds1302_byte
0 19 0 2 write_ds1302
0 90 2 2 rtc_init
0 23 0 3 bin_to_bcd
0 101 2 7 set_clock
0 14 0 0 crono
0 46 1 0 tecla
0 127 2 4 external
0 13 0 0 @const11069
0 22 0 0 TiempoSector
2 481 9 22 welcome
0 23 0 0 @const11102
0 20 0 0 @const11106
0 14 0 0 @const11111
0 11 0 0 @const11126
0 13 0 0 @const11134
1 110 2 1 main
1 42 1 0 KeyPress
Posted: Tue Aug 09, 2005 12:48 pm |
I think no one has answered your post because we think it's
probably the same answer that's been posted 1000 times already.
But anyway, here's the likely answer:
The compiler doesn't normally use all the RAM banks with the PCM
compiler. You have to tell it to use RAM at addresses above 0xFF.
This is done by adding the #device *=16 statement, as shown below.
It should be placed in the next line after your main #include statement.
Example:
| Code: | #include <16F877.h>
#device *=16 |
