interrupt issue
eaton
interrupt issue
PostPosted: Sat Aug 06, 2005 8:59 am     Reply with quote
What does this warning mean.
: Interrupts disabled during call to prevent re-entrancy: malloc
any help,as always is greatly appreciated
Mark
PostPosted: Sat Aug 06, 2005 10:05 am     Reply with quote
Not an error but something doesn't seem right or imformation to the user that he might not realize. In this case, you call a function from an interrupt so the compiler automatically disabled interrupts in that function so that the local variables won't get trashed if you are in that function and an interrupt occurs and that interrupt calls that same function.
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Sun Aug 07, 2005 8:13 pm     Reply with quote
Similiarly, you will see the same kind of warning if you call delay_ms() in an ISR and also in main(). Best thing to do is not to use delay_ms() in an isr.
PostPosted: Mon Aug 08, 2005 6:35 am     Reply with quote
thanks
