EEPROM PROBLEM
leto
EEPROM PROBLEM
PostPosted: Tue Aug 02, 2005 12:57 pm     Reply with quote
I'm using 24256.c driver to read a previously saved content on IC eeprom. I use the read_ext_eeprom function but sometimes it read ok and sometimes it read dirty characters.
I'm readling 20 continuous characters.
I use a 16f877 and FORCE_HW flag. I have connected the pull ups resistor as well.
Is there any function in order to check the read result or something like that ?.
Thank you
Leto.
PostPosted: Tue Aug 02, 2005 1:05 pm     Reply with quote
1. What is your version of the compiler ?
2. Post your #use i2c() statement.
PostPosted: Tue Aug 02, 2005 1:32 pm     Reply with quote
compiler ver 3.203
#define EEPROM_SDA=PIN_C4
#define EEPROM_SCL=PIN_C3
#use_i2c(master, sda=EEPROM_SDA, scl=EEPROM_SCL, FORCE_HW)
for (i=0;i<20;i++) {
sChar[i]= read_ext_eeprom( addr + i );
sChar[i]=0;
return;
thanks
PostPosted: Tue Aug 02, 2005 1:57 pm     Reply with quote
The test program shown below works OK with PCM vs. 3.203
and a 16F877. I tested software i2c and with the FORCE_HW option.
Here is the output:
abcdefghijklmnopqrs
abcdefghijklmnopqrs
abcdefghijklmnopqrs
abcdefghijklmnopqrs
abcdefghijklmnopqrs
abcdefghijklmnopqrs
abcdefghijklmnopqrs
abcdefghijklmnopqrs
abcdefghijklmnopqrs
abcdefghijklmnopqrs
Here is the test program:
#include <16F877.H>
#use delay(clock = 4000000)
#define EEPROM_SDA  PIN_C4
#define EEPROM_SCL  PIN_C3
#include <24256.C>
char sChar[21] = {"Hello World"};
void read_string(int16 addr)
int8 i;
for(i=0; i<20; i++)
sChar[i]=0;
int8 i;
int16 addr;
addr = 0;
// Write string data to eeprom.
for(i = 0; i < 19; i++)
    write_ext_eeprom(addr, 'a' + i);
    addr++;
write_ext_eeprom(addr, 0);
// Read string from eeprom 10 times.
addr = 0;
for(i = 0; i < 10; i++)
    read_string(addr);
    printf("%s\n\r", sChar);
