sshahryiar
Joined: 05 May 2010 Posts: 94 Location: Dhaka, Bangladesh
Driver for 192x64 GLCD with KS0108B Controller |
Posted: Mon Aug 13, 2012 12:56 am |
#define LARGE_LCD
#ifndef HDM64GS192
#define HDM64GS192
#ifndef GLCD_WIDTH
#define GLCD_WIDTH 192
#ifndef GLCD_CS1
#define GLCD_CS1 PIN_B3 // Chip Selection 1
#ifndef GLCD_CS2
#define GLCD_CS2 PIN_B5 // Chip Selection 2
#ifndef GLCD_CS3
#define GLCD_CS3 PIN_B6 // Chip Selection 3
#ifndef GLCD_DI
#define GLCD_DI PIN_B0 // Data or Instruction input
#ifndef GLCD_RW
#define GLCD_RW PIN_B1 // Read/Write
#ifndef GLCD_E
#define GLCD_E PIN_B2 // Enable
#ifndef GLCD_RST
#define GLCD_RST PIN_B4 // Reset
#define GLCD_LEFT 0
#define GLCD_MID 1
#define GLCD_RIGHT 2
#ifndef ON
#define ON 1
#ifndef OFF
#define OFF 0
// Function Prototypes
void glcd_init(int1 mode);
void glcd_pixel(unsigned int8 x, unsigned int8 y, int1 color);
void glcd_fillScreen(int1 color);
void glcd_writeByte(int8 side, BYTE data);
BYTE glcd_readByte(int8 side);
void glcd_update();
#ifdef FAST_GLCD
struct
unsigned int8 left[512];
unsigned int8 right[512];
unsigned int8 mid[512];
} displayData;
// Purpose: Initialize the LCD.
// Call before using any other LCD function.
// Inputs: OFF - Turns the LCD off
// ON - Turns the LCD on
// Initialze some pins
output_high(GLCD_RST);
output_low(GLCD_E);
output_high(GLCD_CS1);
output_high(GLCD_CS2);
output_high(GLCD_CS3);
output_low(GLCD_DI); // Set for instruction
glcd_writeByte(GLCD_LEFT, 0xC0); // Specify first RAM line at the top
glcd_writeByte(GLCD_RIGHT, 0xC0); // of the screen
glcd_writeByte(GLCD_MID, 0xC0);
glcd_writeByte(GLCD_LEFT, 0x40); // Set the column address to 0
glcd_writeByte(GLCD_RIGHT, 0x40);
glcd_writeByte(GLCD_MID, 0x40);
glcd_writeByte(GLCD_LEFT, 0xB8); // Set the page address to 0
glcd_writeByte(GLCD_RIGHT, 0xB8);
glcd_writeByte(GLCD_MID, 0xB8);
if(mode == ON)
glcd_writeByte(GLCD_LEFT, 0x3F); // Turn the display on
glcd_writeByte(GLCD_MID, 0x3F);
glcd_writeByte(GLCD_RIGHT, 0x3F);
glcd_writeByte(GLCD_LEFT, 0x3E); // Turn the display off
glcd_writeByte(GLCD_MID, 0x3E);
glcd_writeByte(GLCD_RIGHT, 0x3E);
glcd_fillScreen(OFF); // Clear the display
#ifdef FAST_GLCD
glcd_update();
// Purpose: Update the LCD with data from the display arrays
#ifdef FAST_GLCD
void glcd_update()
unsigned int8 i, j;
unsigned int8 *p1, *p2, *p3;
p1 = displayData.left;
p2 = displayData.right;
p3 = displayData.mid;
// Loop through the vertical pages
for(i = 0; i < 8; ++i)
glcd_writeByte(GLCD_LEFT, 0x40); // Set horizontal address to 0
glcd_writeByte(GLCD_LEFT, i | 0xB8); // Set page address
glcd_writeByte(GLCD_RIGHT, i | 0xB8);
glcd_writeByte(GLCD_MID, i | 0xB8);
output_high(GLCD_DI); // Set for data
// Loop through the horizontal sections
for(j = 0; j < 64; ++j)
glcd_writeByte(GLCD_LEFT, *p1++); // Turn pixels on or off
glcd_writeByte(GLCD_RIGHT, *p2++); // Turn pixels on or off
glcd_writeByte(GLCD_MID, *p3++); // Turn pixels on or off
// Purpose: Turn a pixel on a graphic LCD on or off
// Inputs: 1) x - the x coordinate of the pixel
// 2) y - the y coordinate of the pixel
// 3) color - ON or OFF
#ifdef FAST_GLCD
unsigned int8* p;
unsigned int16 temp;
temp = y/8;
temp *= 64;
temp += x;
if((x>63)&&(x<128))
p = displayData.mid + temp - 64;
else if(x>127)
p = displayData.right + temp-128;
else if((x>=0)&&(x<4))
p = displayData.left+temp;
if(color)
bit_set(*p, y%8);
bit_clear(*p, y%8);
#else
BYTE data;
int8 side = GLCD_LEFT; // Stores which chip to use on the LCD
if((x>63)&&(x<128)) // Check for first or second display area
x -= 64;
side = GLCD_MID;
else if ((x>127)&&(x<192))
x -=128;
side=GLCD_RIGHT;
side=GLCD_LEFT;
bit_clear(x,7); // Clear the MSB. Part of an instruction code
bit_set(x,6); // Set bit 6. Also part of an instruction code
glcd_writeByte(side, x); // Set the horizontal address
glcd_writeByte(side, (y/8 & 0xBF) | 0xB8); // Set the vertical page address
glcd_readByte(side); // Need two reads to get data
data=glcd_readByte(side); // at new address
if(color == ON)
bit_set(data, y%8); // Turn the pixel on
else // or
bit_clear(data, y%8); // turn the pixel off
glcd_writeByte(side, data); // Write the pixel data
// Purpose: Fill the LCD screen with the passed in color
// Inputs: ON - turn all the pixels on
// OFF - turn all the pixels off
#ifdef FAST_GLCD
unsigned int8 data;
unsigned int16 i;
data = 0xFF * color;
for(i=0; i<512; ++i)
*p1++ = data;
*p2++ = data;
*p3++ = data;
#else
unsigned int8 i, j;
glcd_writeByte(GLCD_LEFT, 0b01000000); // Set horizontal address to 0
glcd_writeByte(GLCD_RIGHT, 0b01000000);
glcd_writeByte(GLCD_MID, 0b01000000);
glcd_writeByte(GLCD_LEFT, i | 0b10111000);// Set page address
glcd_writeByte(GLCD_RIGHT, i | 0b10111000);
glcd_writeByte(GLCD_MID, i | 0b10111000);
glcd_writeByte(GLCD_LEFT, 0xFF*color); // Turn pixels on or off
glcd_writeByte(GLCD_MID, 0xFF*color); // Turn pixels on or off
glcd_writeByte(GLCD_RIGHT, 0xFF*color); // Turn pixels on or off
// Purpose: Write a byte of data to the specified chip
// Inputs: 1) chipSelect - which chip to write the data to
// 2) data - the byte of data to write
set_tris_d(0x00);
output_low(GLCD_RW); // Set for writing
if(side==0) // Choose which side to write to
output_low(GLCD_CS1);
else if(side==1)
output_low(GLCD_CS2);
output_low(GLCD_CS3);
delay_us(1);
output_d(data); // Put the data on the port
delay_us(1);
output_high(GLCD_E); // Pulse the enable pin
delay_us(5);
output_low(GLCD_E);
output_high(GLCD_CS1); // Reset the chip select lines
// Purpose: Reads a byte of data from the specified chip
// Ouputs: A byte of data read from the chip
BYTE data; // Stores the data read from the LCD
set_tris_d(0xFF); // Set port d to input
output_high(GLCD_RW); // Set for reading
else if(side==1)
delay_us(1);
delay_us(4);
data = input_d(); // Get the data from the display's output register
output_low(GLCD_E);
return data; // Return the read data
Please note that this driver works with this GLCD below or similar:
http://www.vishay.com/docs/37364/37364.pdf _________________ https://www.facebook.com/MicroArena
SShahryiar |
