Tokens.txt for IDE
Konrad
Tokens.txt for IDE
PostPosted: Sat Aug 13, 2005 8:04 am     Reply with quote
Anyone worked out how the new option of TOKENS.txt is used with PCWH IDE?
Question
PostPosted: Sat Aug 13, 2005 8:26 am     Reply with quote
Nothing much to 'work out'.
If you create a file called 'tokens.txt', and put text words in it, seperated one per line, then these words will be highlighted in the same way as existing compiler keywords like 'float', 'while' etc., in the souce listings, when loaded through the IDE.
The potential is that if you are writing your own keywords, which you want to be treated this way, it makes the printout clearer.
