digitalfreak
RB5/PGM, 18F452, ICD2 and ICSP |
Posted: Tue Jul 11, 2006 11:59 am |
I am new to ICD2, I use for programming (ICSP) 18F452. I can program, verify, erase fine so I think I got ICD2 right!...The PIC is running good with couple of Steppers and a DC to drive and few sensors. Except the pin RB5/PGM.
I cannot get RB5 to work right!. I did a simple output_high to test, still it didnot work!. Is any there anything I have to do extra for this pin to work?.
I actually want this pin to work as an input.
While programming
I have :
1- MCLR
2- Vdd
3- Vss
4- PGD/RB7
5- PGC/RB6
6- Not Connected.
My fuses are:
Code: | #fuses HS, PUT, BROWNOUT, NOWDT, NOLVP, NOCPD, NOPROTECT, NOWRT |
Plase help,
Thanks |
Posted: Wed Jul 12, 2006 12:29 am |
This problem probably doesn't have anything to do with the ICD2.
You should post this question in the main forum.
http://www.ccsinfo.com/forum/viewforum.php?f=1
When you do that, post a very small test program that demonstrates the
problem. Show all #include, #use, and #fuses statements.
Post a complete program, not code fragments. Also, describe the
external components and circuits that you have connected to pin B5.
But do this in the main forum. |
