Microsoft Serial mouse
sabdullah
PostPosted: Wed Mar 29, 2006 2:51 am     Reply with quote
I am using PIC 16f877 as amouse controller
This is my code in C language
i am using the already example code but i do not make it as interrupt
The computer recognize a serial mouse and shows that it works.
But when i send data for movement or pushing a click it does not work.
i am sure that i send data correctly.. but no respond.
Can any one Help me.
Thanks...
#elif defined(__PCM__)
#include <16F877.h>
#device ADC=8
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOPUT
#use rs232(baud=1200, xmit=PIN_C6, rcv=PIN_C7,errors)  // Jumpers: 8 to 11, 7 to 12
#define MICROSOFT TRUE
#define MOUSE_SYSTEMS FALSE   //not tested.  may not be compatable with Windows
#DEFINE LEFT_BUTTON PIN_B6
#DEFINE RIGHT_BUTTON PIN_B7
#DEFINE MIDDLE_BUTTON PIN_B5
#DEFINE X_CHANNEL 0
#DEFINE Y_CHANNEL 1
struct {
   short int delta;
   short int left;
   short int right;
   short int middle;
   signed int x;
   signed int y;
} mouse;
void clear_all_mouse(void) {
   mouse.delta=0;
   mouse.x=0;
   mouse.y=0;
   mouse.left=0;
   mouse.right=0;
   mouse.middle=0;
#int_ext
void reset(void) {
 #if MICROSOFT
   clear_all_mouse();
   putc(0x80|'M');
void get_data(void) {
   signed int pos;
   if ((input(LEFT_BUTTON))&&(mouse.left)) {mouse.left=0;mouse.delta=1;}
   if ((input(RIGHT_BUTTON))&&(mouse.right)) {mouse.right=0;mouse.delta=1;}
   if ((input(MIDDLE_BUTTON))&&(mouse.middle)) {mouse.middle=0;mouse.delta=1;}
   if ((!input(LEFT_BUTTON))&&(!mouse.left)) {mouse.left=1;mouse.delta=1;}
   if ((!input(RIGHT_BUTTON))&&(!mouse.right)) {mouse.right=1;mouse.delta=1;}
   if ((!input(MIDDLE_BUTTON))&&(!mouse.middle)) {mouse.middle=1;mouse.delta=1;}
   set_adc_channel(X_CHANNEL);
   delay_us(10);
   pos=read_adc() & 0xF8;
   mouse.x=(pos-0x80)/10;
   set_adc_channel(Y_CHANNEL);
   delay_us(10);
   mouse.y=(pos-0x80)/10;
   if ((mouse.x)||(mouse.y)) {mouse.delta=1;}
void send_data(void) {
#if MICROSOFT
    putc(0xC0 | (mouse.left << 5) | (mouse.right <<4 ) | ((mouse.y >> 4) & 0x0C) | ((mouse.x >> 6) & 0x03));
    putc(0x80 | mouse.x & 0x3F);
    putc(0x80 | mouse.y & 0x3F);
#elif MOUSE_SYSTEMS
   putc(0x80 | (!mouse.left<<2) | (!mouse.middle<<1) | !mouse.right);
   putc(mouse.x);
   mouse.x=0;
   putc(mouse.y);
   mouse.y=0;
   putc(mouse.x);
   putc(mouse.y);
   mouse.delta=0;
   mouse.x=0;
   mouse.y=0;
void main(void) {
   clear_all_mouse();
   setup_adc_ports(RA0_RA1_RA3_ANALOG);
   setup_adc(ADC_CLOCK_DIV_2);
   ext_int_edge(H_TO_L);
   enable_interrupts(int_ext);
   enable_interrupts(global);
   while (TRUE) {
      get_data();
      if (mouse.delta) {send_data();delay_ms(17);}
