C Algorithm Help Needed
glenjoy
PostPosted: Mon Aug 08, 2005 12:25 am     Reply with quote
I have these data, it is formatted as [0x0D][0x0A][message][0x0D][0x0A][message][0x0D][0x0A] and [0x0D][0x0A][message][0x0D][0x0A]
What I need is to get all data and stop once the last 0x0A is received.
I had a solution already but my problem is that I use two algorithms to process each of the said data, one subroutine for [0x0D][0x0A][message][0x0D][0x0A][message][0x0D][0x0A] and another subroutine for [0x0D][0x0A][message][0x0D][0x0A].
Now what I need is to use only one subroutine in processing both said data.
Thanks.
PostPosted: Mon Aug 08, 2005 2:54 am     Reply with quote
Use gets() to read the data stream up to and including the CR\LF combination.
Study the literature about 'state machines' to learn about how to effectively process the messages.
Humberto
PostPosted: Mon Aug 08, 2005 6:16 am     Reply with quote
IMO it´s not usual nor well defined this format, it is not a formal protocol,
just a kind of string delimiter.
It will have a pause after the delimiters to flush the buffer.
You must copy the whole buffer before the next [0x0A] if not, it will overwrited.
Anyway this code will do the job, it´s not tested.
#define Rx_size 20  // I don´t know the message long
int8 Rx_buffer[Rx_size];
int8 index, mssge;
#int_RDA
void rcver_int_handler()
int8 rcved_char;
      rcved_char = getc();
      if( rcved_char == 0x0A )
        { index = 0; mssge = TRUE; }
      if( rcved_char == 0x0D )
        { mssge = FALSE; }
      if( mssge )
        { Rx_buffer[index] = rcved_char; index++; }
Humberto
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Mon Aug 08, 2005 3:50 pm     Reply with quote
Humberto wrote:
IMO it’s not usual nor well defined this format, it is not a formal protocol,
Humberto, don't be so harsh. It is a protocol. A protocol for transferring strings. What would be a usual format? (This is not just rhetoric question.) However, I have to comment that our friend GlenJoy didn’t mention one important thing: the [message] should not contain 0x0A and 0x0D, or it should have an escape sequence for these bytes.
Humberto's algorithm can be made more robust, if you have 2 (or more) receive buffers instead of one. (some times it’s called “ping-pong buffers”) While one is being processed by your main() thread, the other one is filled by your RDA ISR. That way, you will have more time to process the data. Of course the degree of success of such an improvement depends on the duty cycle of your communication stream.
int8  index, mssge, newdata;
#int_RDA
      int8 rcved_char;
      int8* pTemp;      // used for swapping
      // some validation code goes here.  e.g. [numbers,characters,0x0A,0x0D only
      switch (rcved_char)
         case (0x0A):
            index = 0;
            mssge = TRUE;
         case (0x0D):
            mssge = FALSE;
            // swap the old and the new buffers
            pTemp = pOldBuff;
            pOldbuff = pNewBuff;
            pNewBuff = pTemp;
            newdata = TRUE;// flag that you have a whole new message
         default:
            if (mssge)
               pNewBuff[index] = rcved_char;
               ++index;
               // out-of protocol character.
               // some whaco had connected the serial cable God only knows where.
               // alert the user, or just ignore.
   pOldBuff = &Rx_buffer0;
   pNewBuff = &Rx_buffer1;
   newdata = 0;
   mssage = FALSE;
   if (newdata)
      // process data in the OldBuff
      newdata = FALSE;
Humberto
PostPosted: Tue Aug 09, 2005 12:32 pm     Reply with quote
Kender, please keep the conversation civil and respectful.
I feel your comments very agressive, be aware that I will not admit any kind of judment from you nor from anybody. English is not my natural languaje so you would be aware that inadvertidely I can use some words that will sound not so fair-spoken for yours.
Just post your code and keep your unasked opinion regarding another people.
Regarding the point if it is a protocol or not, I posted my thread and I tried to be prudent and started the phrase with IMO (in my opinion) being in advice that such format is an opinable matter.
Protocol from Wikipedia:
"It is difficult to generalize about protocols because they vary so greatly in purpose and sophistication.
Most protocols specify one or more of the following behaviors:
- Detection of the underlying physical connection (wired or wireless), or the existence of the other endpoint or node
- Handshaking
- Negotiation of various connection characteristics
- How to start and end a message
- How to format a message
- What to do with corrupted or improperly formatted messages (error correction)
- How to detect unexpected loss of the connection, and what to do next
- Termination of the session or connection"
In computing, a protocol is a convention or standard that controls or enables the connection, communication, and data transfer between two computing endpoints.
In the field of telecommunications, a communications protocol is the set of standard rules for data representation, signalling, authentication, and error detection required to send information over a communications channel."
I´m still consider that the format [message][0x0D][0x0A] it is very primitive to be considered a real protocol, unless it is transmitted in burst of strings with a marked pause at the end.
One of the advantage of using a protocol is that it has enough self contained information that the receiver knows exactly where and when is the beggining of a message, that I can´t determine clearly in the preceding example.
Humberto
